What powers your SCX10?
ericinMD
Salisbury, Maryland
Please list your SCX10 Motor, Battery, and ESC here!
Which battery type/ number of cells and with what motor, ESC and gearing? I guess if you are using larger than stock tires or anything else that would affect the end result, that would be good to know as well.
example- 2S Li-Po, Tekin FXR, Integy 35T lathe motor, stock gearing
You can keep checking back to this original post for updates as we gather the info. Thanks!
EDIT: As of Post #111
Batteries Listed:
2S Li-ion............. 1
6S Li-Po.............. 1
4S Li-Po...............1
3S Li-Po.............35
2S Li-Po.............32
Unspecified Li-Po...2
6 Cell Nicad.......... 1
8 Cell Ni-MH..........2
7 Cell Ni-MH..........4
6 Cell Ni-MH.........17
ESCs Listed:
Axial............................ 1
Castle Sidewinder..........12
Castle Mamba Max..........7
Castle Mamba Max Pro.....2
Dynamite Tazer.............. 1
EZ Run 60 amp BL........... 1
Holmes TorqueMaster......4
LRP Crawler...................1
LRP Micro......................1
LRP Quantum Runner.......2
MRC............................ 1
Novak Goat Crawler.........6
Novak Havoc pro............ 1
Novak Rooster Crawler.....12
RC4WD Mayhem..............2
Robbe Rookie Truck......... 1
Tamiya TEU-101BK......... 1
Tekin FXR.....................20
Traxxas VXL-3................2
Traxxas XL-5.................14
Turnigy BL 35A...............1
YeahRacing 35A BL......... 1
Motors Listed:
Axial 27T.............................. 7
Axial 55T.............................. 4
BL Outrunner 3500Kv.............. 1
Checkpoint 9T....................... 1
CKRC Twister 35T................... 1
EZ Run BL.............................. 1
Fantom 35T Hand Wound..........1
Holmes 30T........................... 2
Holmes 35T........................... 3
Holmes Cobalt Puller 7T........... 3
Holmes Cobalt puller 10T.......... 1
Holmes CM 3014 850Kv BL........ 1
HPI Saturn 35T...................... 1
Hyperion 3100Kv Sensored BL....1
Integy (various series) 35T......10
Integy (various series) 40T...... 1
Integy (various series) 45T...... 5
Integy (various series) 55T ..... 2
JP Warrior Hand Wound............ 1
LRP 21.5T Crawler...................1
LRP Truckpuller2..................... 1
Novak 45T.............................1
Novak 55T ............................4
Novak Ballistic BL................... 2
Novak Goat BL .......................5
RC4WD 45T........................... 1
Reedy 55T............................ 1
Reedy MVP 27T ..................... 1
Reedy Spec 19T..................... 1
Tamiya Silvercan.................... 2
Tekin 35T (Machine Wound)..... 4
Tekin 35T Pro Handwound........ 10
Tekin 45T Pro Handwound........ 1
Traxxas 12T 550..................... 4
Traxxas 21T 550..................... 1
Turnigy 480S BL 3200Kv .......... 1
Unspecified make 35T.............. 1
Unspecified make 55T.............. 4
Unspecified 1800Kv 3661 BL...... 1
Velineon 3500Kv BL.................. 1
Venom Fireball 55T.................. 1
I plan on trying my 1800 3s Lipo with a Slash XL-5 and a Novak 55 with a CC BEC. I hope the 3s doesnt fry the ESC. I think the high turns in combination with the BEC will help (I hope).
HH 35t, 87/18 gearing, 7.2V C NIMH, XL-5. Using Flat Irons.
5400 2s lipo from losi, and novak goat, awesome setup!"thumbsup"
19t pinnion
2 cell 5400 lipo from duratrax
castle creation mamba max esc
9 t checkpoint motor :twisted: insane power
87t spur - 21t pinion
Novak Rooster
55t Integy comp motor
Spur 87
Pinion 12
1.9 rok loks
3000 stick pack
3oz. per front tire/none in the rear
Climbs like a goat and really earns that Toyota badging on the front.
SCX10 - 1 - 1.9 Blazer
35t integy
stock gearing
8.4v elite 4000mah
novak rooster
SCX10 - 2 - 1.9 10" wb clod based flatbed
35t integy
stock gearing
7.4v 5000mah 35C elite lipo
waterproof xl5
- this truck is still in process, but this is the plan so far
SCX10 - 3 - 1.9 JK
40t integy pro
hpi gru feeding axial tranny for transfer case
sidewinder
this rig will get a 3 cell when it's done - wheeled pretty good with 8.4v nimh and an xl10 though
I have a 27t Reddy MVP motor, with a lrp quantum runner esc. For batteries I'm just running some junker nicd's and nimh's. All 6 cells. I do alot of water running and such with it, and its a blast!
scx10 running a traxxas vxl-3 esc and a velineon 3500kv motor with 35 tooth pinion and 69 tooth pinion and only a 7.2 volt battery until i extended the wheel base of the rear ,it was undriveable all it would is wheelstand
