tonyfalkon
Just a tip to those who might do this mod you can cut the tube shorter to use the 5 mm thread or not put any tubes at all so you can use 6 mm bore hubs instead of the 8 mm. The distance between the the edge of the bearing to the center of the pinhole is 8.5 - 8.7 mm.
Also on the 6 mm tempered rods to replace the diff outdrive cup, you can use old bent/discarded YXL rear axles if you can get 26 - 27 mm from those just make sure your pinholes are centered.
