I recently purchased a 1/18 18.5t sensored motor and Xcelorin ESC for my mini rock crawler pro.
It worked flawlessly for a few days.
I first noticed this the other day. At the top of an incline the crawler buzzed and stopped moving. I thought it was the slipper but found it odd because the truck was not in any kind of bind.
I used the truck yesterday and was doing some serious crawling with a buddy. He has a novak system in his and up until yesterday My Xcelorin system kept right up with the Novak. Once again the truck stopped moving and began to buzz. I let off and the truck rolled back about an inch and then it powered through ok. The buzzing and stopping got worse so I quit until I could get a really good look at what was happening.
I thought maybe a tooth in the tranny stripped so I took it apart and there was nothing wrong inside. All gears looked great. They should the truck is only a couple weeks older than the Xcelorin system.
I crawled across the couch and it buzzed again. I stopped and looked closely at what was happening. The motor was buzzing and the pinion was moving moving back and forth very quickly about an 1/8 of an inch. I let off the throttle the truck rolled back a bit and then it crawled over the obstacle. Now even rolling across a level floor at half throttle or even full throttle ( it doesn't matter what speed now) it will buzz for a split second and keep moving. I just tried a little bit ago and now the truck will go full power (wheels off of the ground) and all of a sudden go to half throttle. The ESC shows an orange light. Turned off then on again the truck will do the same thing.
Any ideas here? I've been reading about Xcelorin systems and the problems people have encountered. Does this sound like bad sensors inside the motor? I am not having any luck getting answers on LOSI's forum. I've asked other questions and no response.
I hope someone is listening and has some help to this problem.
