Interesting video, now I know what torque twist is...
Torque twist can be tamed with sway bars and shock preloading, but can't be eliminated, unless you want to convert to IRS, such as with the Bomber B2B or
my Yeti IRS project.
Bussen back to the original question: what is it that makes an IFS Bomber superior to the Yeti? svt923 claims it "jumps better, flies better, lands better, soaks up the terrain better" which is certainly true,
Certainly claimed to be true. 8)
but why? What is it in the geometry that accounts for all that? Even more nimble and quicker? I don't get it.
Neither do I, but then this is the internet where things are right or wrong, black or white, cut and dry, and completely self-evident to those making the claim. ;-)
But seriously, while I think of the stock bomber as a good choice for a crawler and trails truck, what is best for anyone depends on where and how they use it.
I do find it strange, in the case of the B1B, how the same parts forming the same suspension with the same geometry but with two different bodies/pans creates one truck that is derided - even hated - and another is somehow faster with the same drivetrain and more nimble with its higher CoG. I guess I’ll have to wait to see the video of this truck in action. :shrug:
Since my yeti is my only active rig at this time, I put a low-mass body on it, and went to the local crawling spot; 52.7 km/h on the GPS for a top speed, and it still crawls well enough without overheating the factory sensorless motor-esc combo. Other than the spur (and rusted slipper plates) and the rtr servo, I've not had any breakage, but then I don't drive it like it is an arrma stunt truck.
The suspension on these vehicles (like all vehicles) is about compromise. For example, if you watch
my video, you can see where the truck lifts the inside wheels on deceleration into corners, due to the putty in the front diffs, a handling vs traction compromise.
Thinking of buying a Yeti from scratch up (by a hundred mail orders), maybe I should do an IFS Bomber instead. Might not be that much more expensive than a upgraded Yetithat way. Which I by the way understand is an expensive way of building a car, but it would be a very long lasting and challenging project and therefore maybe worth the extra expense to Mr.
I think your money could be better spent buying a bomber or a yeti, and getting an idea of what you want to do with it (speed/trails/crawling) and the build from there, but it depends on your situation. The kits are a better way to go cost wise, if you have all of your electronics already sorted out, which I did not. I’ve built many kits, but I went the RTR (yeti) route this time as it allowed me to get back into the hobby and take my time getting familiar with the new motor/esc/battery technologies on the market, while having a truck on the ground and getting outdoors with my son and his truck. YMMV.
Good luck with your search.
