Which SCX10 ii? Raw Builders Kit, Cherokee Kit or RTR
Can make the RBK surpass the TK with SSDs own parts easily for cheaper then the TK itself though.
Hmm, care to elaborate? Just the front axle and transmission alone + RBK would make it more expensive than the TK and that’s excluding shocks, the scale motor/fuel cell, drive shafts, and superior links.
The 10.2 can definitely be made into a heck of a rig though. No arguing that, just saying there is good value in the TK assuming one wants the scale transmission.
Buy the heavier axle housings, overdrive gears, brass knuckles, stainless lower links etc and you'd be better off with the RBK to start.
Not saying the TK is a bad value, I'm saying if your plan is to upgrade it, the RBK is a better base to begin with, throwing away less money. I run brass links and chubs also for example with the lower stainless links and adjustable shock mounts all around with big bores. My RBK is now built like an ultra TK, would have wasted a ton more money if I started with the TK.
I love the scale transmission, in fact it's practically required for my local comp, but I'm not convinced it's placement with the battery stuffed in the back performs better then the standard SCX10.2 setup.
I'd rather toss the crap Axial shocks in favor of TRX4 or even big bores over the SSD shocks, just my preference not to throw more money away then I need too.
I'll reiterate, the TK is a fantastic truck, unless you're upgrading beyond it and replacing all those expensive parts to begin with.
I appreciate you elaborating, and fair points. I agree that the TK transmission is arguably more for scale and not as much for performance almost strictly because of the battery placement. If one isn’t interested in the transmission then I agree the RBK is great option.
I left this out of my last post, but my 10.2 Cherokee kit build with the ssd goodies, samix battery tray, and a lot of what you mentioned in your post, climbs better than my trail king. The TK ain’t far behind but the 10.2 has the vertical advantage.
Case and point I haven’t hit this line in my TK yet, but have hit it in the 10.2 JK, a trx4 (heavily modified), and the trx10.2. Hoping to get the TK up this line some time this spring as I continue to tinker with it and try a lighter battery.
<blockquote class="instagram-media" data-instgrm-permalink="https://www.instagram.com/p/B7PGqfIAU6G/?utm_source=ig_embed&utm_campaign=loading" data-instgrm-version="12" style=" background:#FFF; border:0; border-radius:3px; box-shadow:0 0 1px 0 rgba(0,0,0,0.5),0 1px 10px 0 rgba(0,0,0,0.15); margin: 1px; max-width:540px; min-width:326px; padding:0; width:99.375%; width:-webkit-calc(100% - 2px); width:calc(100% - 2px);"><div style="padding:16px;"> <a href="https://www.instagram.com/p/B7PGqfIAU6G/?utm_source=ig_embed&utm_campaign=loading" style=" background:#FFFFFF; line-height:0; padding:0 0; text-align:center; text-decoration:none; width:100%;" target="_blank"> <div style=" display: flex; flex-direction: row; align-items: center;"> <div style="background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 40px; margin-right: 14px; width: 40px;"></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 100px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 60px;"></div></div></div><div style="padding: 19% 0;"></div> <div style="display:block; height:50px; margin:0 auto 12px; width:50px;"><svg width="50px" height="50px" viewBox="0 0 60 60" version="1.1" xmlns="https://www.w3.org/2000/svg" xmlns:xlink="https://www.w3.org/1999/xlink"><g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g transform="translate(-511.000000, -20.000000)" fill="#000000"><g><path d="M556.869,30.41 C554.814,30.41 553.148,32.076 553.148,34.131 C553.148,36.186 554.814,37.852 556.869,37.852 C558.924,37.852 560.59,36.186 560.59,34.131 C560.59,32.076 558.924,30.41 556.869,30.41 M541,60.657 C535.114,60.657 530.342,55.887 530.342,50 C530.342,44.114 535.114,39.342 541,39.342 C546.887,39.342 551.658,44.114 551.658,50 C551.658,55.887 546.887,60.657 541,60.657 M541,33.886 C532.1,33.886 524.886,41.1 524.886,50 C524.886,58.899 532.1,66.113 541,66.113 C549.9,66.113 557.115,58.899 557.115,50 C557.115,41.1 549.9,33.886 541,33.886 M565.378,62.101 C565.244,65.022 564.756,66.606 564.346,67.663 C563.803,69.06 563.154,70.057 562.106,71.106 C561.058,72.155 560.06,72.803 558.662,73.347 C557.607,73.757 556.021,74.244 553.102,74.378 C549.944,74.521 548.997,74.552 541,74.552 C533.003,74.552 532.056,74.521 528.898,74.378 C525.979,74.244 524.393,73.757 523.338,73.347 C521.94,72.803 520.942,72.155 519.894,71.106 C518.846,70.057 518.197,69.06 517.654,67.663 C517.244,66.606 516.755,65.022 516.623,62.101 C516.479,58.943 516.448,57.996 516.448,50 C516.448,42.003 516.479,41.056 516.623,37.899 C516.755,34.978 517.244,33.391 517.654,32.338 C518.197,30.938 518.846,29.942 519.894,28.894 C520.942,27.846 521.94,27.196 523.338,26.654 C524.393,26.244 525.979,25.756 528.898,25.623 C532.057,25.479 533.004,25.448 541,25.448 C548.997,25.448 549.943,25.479 553.102,25.623 C556.021,25.756 557.607,26.244 558.662,26.654 C560.06,27.196 561.058,27.846 562.106,28.894 C563.154,29.942 563.803,30.938 564.346,32.338 C564.756,33.391 565.244,34.978 565.378,37.899 C565.522,41.056 565.552,42.003 565.552,50 C565.552,57.996 565.522,58.943 565.378,62.101 M570.82,37.631 C570.674,34.438 570.167,32.258 569.425,30.349 C568.659,28.377 567.633,26.702 565.965,25.035 C564.297,23.368 562.623,22.342 560.652,21.575 C558.743,20.834 556.562,20.326 553.369,20.18 C550.169,20.033 549.148,20 541,20 C532.853,20 531.831,20.033 528.631,20.18 C525.438,20.326 523.257,20.834 521.349,21.575 C519.376,22.342 517.703,23.368 516.035,25.035 C514.368,26.702 513.342,28.377 512.574,30.349 C511.834,32.258 511.326,34.438 511.181,37.631 C511.035,40.831 511,41.851 511,50 C511,58.147 511.035,59.17 511.181,62.369 C511.326,65.562 511.834,67.743 512.574,69.651 C513.342,71.625 514.368,73.296 516.035,74.965 C517.703,76.634 519.376,77.658 521.349,78.425 C523.257,79.167 525.438,79.673 528.631,79.82 C531.831,79.965 532.853,80.001 541,80.001 C549.148,80.001 550.169,79.965 553.369,79.82 C556.562,79.673 558.743,79.167 560.652,78.425 C562.623,77.658 564.297,76.634 565.965,74.965 C567.633,73.296 568.659,71.625 569.425,69.651 C570.167,67.743 570.674,65.562 570.82,62.369 C570.966,59.17 571,58.147 571,50 C571,41.851 570.966,40.831 570.82,37.631"></path></g></g></g></svg></div><div style="padding-top: 8px;"> <div style=" color:#3897f0; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:550; line-height:18px;"> View this post on Instagram</div></div><div style="padding: 12.5% 0;"></div> <div style="display: flex; flex-direction: row; margin-bottom: 14px; align-items: center;"><div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(0px) translateY(7px);"></div> <div style="background-color: #F4F4F4; height: 12.5px; transform: rotate(-45deg) translateX(3px) translateY(1px); width: 12.5px; flex-grow: 0; margin-right: 14px; margin-left: 2px;"></div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(9px) translateY(-18px);"></div></div><div style="margin-left: 8px;"> <div style=" background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 20px; width: 20px;"></div> <div style=" width: 0; height: 0; border-top: 2px solid transparent; border-left: 6px solid #f4f4f4; border-bottom: 2px solid transparent; transform: translateX(16px) translateY(-4px) rotate(30deg)"></div></div><div style="margin-left: auto;"> <div style=" width: 0px; border-top: 8px solid #F4F4F4; border-right: 8px solid transparent; transform: translateY(16px);"></div> <div style=" background-color: #F4F4F4; flex-grow: 0; height: 12px; width: 16px; transform: translateY(-4px);"></div> <div style=" width: 0; height: 0; border-top: 8px solid #F4F4F4; border-left: 8px solid transparent; transform: translateY(-4px) translateX(8px);"></div></div></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center; margin-bottom: 24px;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 224px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 144px;"></div></div></a><p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;"><a href="https://www.instagram.com/p/B7PGqfIAU6G/?utm_source=ig_embed&utm_campaign=loading" style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none;" target="_blank">A post shared by topherBuilds (@topherbuilds)</a> on <time style=" font-family:Arial,sans-serif; font-size:14px; line-height:17px;" datetime="2020-01-12T22:21:58+00:00">Jan 12, 2020 at 2:21pm PST</time></p></div></blockquote> <script async src="//www.instagram.com/embed.js"></script>
I definitely don't detract from the TK in any way at all.
I think SSD has nailed the affordable aftermarket goodies, I'm pretty well addicted to their products and only look elsewhere when they don't have what I need.
Price vs performance can't be beat.
All I'm saying is that for MY needs, the TK didn't and won't really ever make sense, I WILL replace what it comes with, with SSD's own better performing parts, and what they don't offer, I get from another company.
It's a fantastic truck and a great value, if you leave it alone, something I'm incapable of doing.
I get what you are saying but in my opinion the trans on the TK is part of the performance and balance of the rig. The quality of the parts is the other half. You can upgrade the TK further but it really isn't necessary. The SBK is terrible out of the box and requires upgrades to steering immediately. Shocks are typical Axial crap, and it flops at the slightest sidehill even in good tires and foams. If money is the issue a GS02 Komodo/BOM or TRX sport is far superior. Going to upgrade my 10.2 more for balance but only reason I have it is for Axialfest at this point. Another pro for the TK is the ability to have a full and deep interior. I like to be scale. I full expect a 10.3 soon.
Sent from my Moto G (5) Plus using Tapatalk
Agreed, as I said previously...
I was able to get the RBK driving under it's own power yesterday.
Shimming the drivelines .30mm helped the R&P's quite a bit. Other things that were changed right from the start was a metal servo horn and I flipped the 3 upper link ends at the skid plate to avoid interfering/binding with the lower links.
So far, I'm happy the way it operates and am looking forward to getting a body installed.
y4m9sStN_HoqVuqji8lb4TGwno8atr2fCfXKtGCubxxG6Iy-_5DzpJGEIal1mYYIgNyMWJH8pbouBWOIXnHgHUO8ZUDm4-tHYCJmOScGT0nc8dJL-sv4ctcSc51u3Qrt8uHFUrz-VN5l7QMBw1swmPRuoBDuv3lNIhPqnDtu67QYJHYCXYo35_psBDdIW9v77U-o8dUTDzlPlmarehuZzA3VA
Don't forget to enable freewheeling on your 1080. NOT the default setting.
What exactly does freewheeling do? I read about it but didn't quite understand.
Progress Update: I'm still continuing to fine tune the SCX10 ii and loving it. The Proline '85 Toyota SR5 Hilux body is now being fitted and painted. The body was listed as a 12.3" wheelbase. Using the recommended body mount hole locations and lining up the front axle to the fender arches, shortening the WB to 12" made it spot on. The tires on it right now are listed as 4.25" and those will be changed out for 4.19's to be compliant with Class 1. So far, I'm really happy with it.
12" wheelbase, 4.25" tires, 1.9 wheels
y4mZLxyYN6ftv-7CCwqqLYq-NM0UE04vxA2L4zm8BIaCkQJJ86sxExFs-mfkN21q_bt_jtlrAVwNIwp2ZJ9WvylIAeznWC5vbXYmFF9fSsVHmqyNlcIw7NNkE5ekUfSZe-RsZZHSu5R4Abd8AwXgFyeaMgWyCf8MFP8V7P3DrpYgQOPNfbLW1h2ro2Gj7UW4dToxuMo-vgaKgIiGLaMCUSdEg
Testing at Pacific RC Arts. Pictured with my son's ECX Barrage Sumo Samurai running RC4WD 1.55 Mud Thrashers.
y4mK-_bG4HA7KivFdnKa0j-23_zENczI32objsfOd_oFvnO4TiO0X7hkp70_K8fqr3rMLNnwvIBi-Vt9FtZ_HhiNrX2xmSTBiZE0XJQgFT1BcmrRrD0hTjE5n45s7Hc8wXONE4u-LMCNK-15BHYwl9iIWKbhphc0dahOXbmlYm6aGbg_gOyNlfi5MhfKD9F-lxmo2EpukoWgkHttcN67nmLGw
Lookin' good!
There are in-depth threads here on Freewheeling theory, but in a nutshell, what it has done for me is make my rig silky smooth to the trigger when inching down steep inclines slower than a snail, where there's lots of good traction. No herky-jerky.
Made the dragbrake adjustment and it does work well. Descending down grades was really smooth and steady.
My progress:
The Proline Toyota '85 SR5 Hilux body was painted and turned out ok. I'm still learning the paint process and would like to buy another body and try it again in drier, less humid weather.
For wheels and tires, I bought the wheels off of Amazon. They were cheap ($39.99) but are round, beadlocks and effective. I especially like that they are period correct of wheels that were available in the late '80's and early '90's. The tires are Proline BFG KM3 Class 1 4.19" in the K8 compound. With the weight of the metal wheels over plastic, added hardware and new tires, the net gain was 7.45 oz of unsprung weight to the truck. The truck now weighs 5.25 pounds and acts very predictable as I am learning to drive it.
y4mmIlXLd1YUtCdDvcZnpILK57uQQln3_iZdiJIEeQDsKX-_3TtStmc6SfdwVAmpp_v9UM1bMo_jOdDF2MHUEd48Nx0jNetwP8fEu3yovISbhCY5M0JaoiWxTHVOfUvxs0UxNNdAIQn5800V-DihpMJMH6h_Yns_QsPgFDooVFwHoZQpOZ254UqdV_TO6DPJ-1L9nETDO4Ew6dNnT7UA0CqkA
y4m4eYqE_K2bvsO1UdPTlSfGcAPa0m5DDxkVathZqcxpEX1zeHQEwT8zkXMRL7zWNrrpNLPtLs1AUxOav4hE9zylKSF1KKydey3vqP5qcRQ8stwwjkNeCKCoKf-cSFQnjHUD57gnEpr4mHFbtYLhnLkUk5TeKCpsQnYiuBcRGPbNRhbAKDpg8cFPadS4SkacJFCg9hYdF1L7YnLHD_8IA2yoA
y4mJmFqc4wyIPd1f1FlHi857T86dB339jHYPzla2NYL18l8twAjuGFQ_b3LdhHqbBwxLkMMbZl5T5JuHbBG8BjBESaqwx_XyBrJBlk3-cvfws5ek3_CcFTdiD5QXtSfBMwncnj9eOGymcg_2xJWa9hE9veYwrSuiAzickSDUhl4vvBmgU_oDPiuRrILXPJohKd9Zze3FJ9YT3t0hSIK4RftZQ
