wheels spinning in tires
cbcmad
lyman
I recently got some rc4wd stock wheels and baja claw ttc,tightend them all the way down but the wheels are spinning inside the tires under pressure:x.Is there a trick to stop this?
These wheels suck I had to wrap electrical tape around the inside to fill the void. Since then they work awesome! Hope this helps
try the tape first... hopefully it works.. if not worst case pick up a bottle of thin CA glue from your LHS and pull tire off rig, peel back the tire bead and add a drop then spin the tire 180* and add another drop.
with the glue it wont move around but will be harder to get the tires off the rim when you need to.
Shoe Goo also works very well at keeping it in place while still being easier to remove the tires if needed. You can pick a big tube up from wal-mart for about $3-$5 "thumbsup"
