What did you do to you SCX-10 today?
Installed the new Vanquish link kit on my Rubicon. No run time on it yet but I like it a lot better than the the front Y and rear plastic links!
Collecting parts for 3s
32p 11t pinion and 56t spur
Also ordered 2 2200mah 3s lipos
Now just waiting for holmes to get 35t torquemaster sports in stock
And just bit the bullet on a stable mate. Have an axial deadbolt en route
Removed the factory eletronics box in favor of a radio shack box. Stuffed everything but the BEC inside it for now, but i've still got HeyOK led and winch controls coming. Not sure it will fit.
Also ditched the burned out RX (at least i think it's the RX, i'll find out for sure when the new AX-10 gets here and i can test it) for a Flysky 8 channel RX and hacked the GT3C. Had to remove the RX from it's case though to fit it plus the wiring into the electronics box
Also, ordered a Holmes 35t Torquemaster Expert motor. So, now i'll have the AE-2 (with bec for steering) 2x 2200mah 3s batteries (only drawing juice from one at a time) saddle mounted, 32p 11t pinion, 32p 56t spur, and now a 35t holmes motor. Should be a beast!
Also ordered a soldering station so i'll be able to clean up the wiring further (Run my own wires instead of using multiple extentions with the way the ESC and eletronics are mounted.
Got to use the plow and VP light bar
Started the tear down and built a rear shock relocation kit to get ready for a rc4wd mojave body. Still have to move all the electronics so I can move the battery up front.
I got my new to me motor (crawlmaster 1340) when I tested it out of the truck then when I installed it I had 2 wires switched and fried my sidewinder esc :(
Cut fender flairs off my nb jk body, started on a roll cage, finished installing and wiring up rock lights, made rear inner fenders, and installed my cc bec
R2J rear 4 link truss and custom rear 4 link. Cvds all the way installed. New bearings in front axle. And getting started on custom cms!!!! Can't wait to see how it turns out!
