soslowski
with the grease trick do you open the receiver case and pack it or do you encase the outside? will it overheat?
I just did a write up yesterday on waterproofing the new stock axial electronics. Could prolly help you out a bit. I only cover the esc, led board and receiver. The servo is easy to seal (YouTube it) and I'll have to look more at the motor. Haven't got that far yet.Should clear up some unanswered questions in the thread, I have read all the thread, and searched high and low, but is there a list of what is waterproof and what is water resistant? and what is NOT waterproof?
I know from previous threads that the Axial 27T motors are NOT waterproof.
I know that the Hitec 645MG is water resistant, but with a tab of dialetric grease at the output shaft, it is waterproof.
The axial AE-1 is NOT waterproof. and i've heard that plastidip and dialetric grease will do the trick, is there a website with step by step procedures? that would help great as this would be my first time, and my brother's in law's first time. I know that this ae-1 gets really warm to the touch when we first used it, because the servo was defective and drawing too much power, so we then realized that the balloon would melt under stress?
The axial receiver box is NOT waterproof, just a splash guard. shouldn't be too hard to waterproof the box with some silicone at the wires.
My brother in law owns the Dingo RTR, he wants to waterproof it, but he doesn't trust a baloon around the motor for the obvious reasons it needs air? would it be ok if the motor was in a sealed compartment? I've seen others do it with success. ist he axial 27t motor any different?
as for the battery connection, do you just put dialetric grease all over the plug inside and out? and its ok for disconnecting and reconnecting to charge? and the dialetric grease will still remain in tact for the next run? or do you have to cover the plug in grease everytime you plug the battery in.
oh and the battery is NIMH so it is safe from what i read above. its LIPO that u need to worry about.
sorry about the noob questions, but little unsure.
they are NOT waterproof , you will fry it out if it goes for a swim.
there are some great write ups on RCC on how to waterproof them or you can go on YOUTUBE , there are a bunch of videos on it.
No they are not waterproof. They have small rubber seals that help with water and dust intrusion. So basically, they are water RESISTANT. Not submergable. Plus they don't have enough torque to be used on a crawler. If they are water tight, they will say WATER PROOF. Get a hitec 5645.
Also the esc in the new emaxx is the marine water proof one
Here is a good water proof esc with no reverse delay
http://www.horizonhobby.com/Products/Default.aspx?ProdID=PRB2314
Hi guys,
can i waterproof my electics with silicon spray?
