It looks like you removed a lot of material from the motor plate. Was all of that needed in order to get a 13 tooth pinion in there?
So I revisited the gearing on my SBK and decided to try out a 3:1 GRU/planetary gear unit from Xtra Speed. I'm loving the super low gearing a lot but It did add a lot of extra length and weight to my rig as its a dense little unit. I was trying to keep this rig lightweight but I may just live with the extra mass as I'm really liking the gear ratio I get with it. Lucky for me I hadn't nailed down the body mounting and was able to adjust it to fit the longer motor and GRU.
Its my first time using a GRU but as all of them state they are "Not intended for use with brushless motors", they just arent strong enough.
I think the best starting point for a slow Venture is likely a very slow motor that way you can gear up from there if needed.
Would you recommend the unit? I have tried my 45T 540 motor and it's still to fast for my liking. So I was considering try the unit that is why I am asking if would recommend it. Also was there a noticeable difference in the speed reduction?
Looks a good idea, but I am trying to keep the weight down. My Holmes 30t with 14t pinion is a bit fast, but with the MMPesc I can set the throttle curve. A bit more fine tuning and should be fine. I just with the weather would cooperate.
Yes this will slow your rig down considerably, top speed is a very slow walking pace (maybe I'll take a short video later). If you are ok with the downsides of the added weight (its like adding an extra motor) and the extra length added to the motor which is 25mm. You'll need to make sure you have room with the body you're using, I'm using Proline's Dodge Power Wagon and it barely fits. I also expect this unit to have a short-ish lifespan so thats another thing to consider.
Yeah I'm not super happy with the extra weight, its very nose heavy now as if it wasn't already. I was able to get a nice slow crawl with a throttle curve but found it lacking when going downhill. It really shows the high gear ration when you start to coast down hill.
Great idea there. Could the stock one not be modified though? I haven't had a look as I'm busy doing boring stuff at home that's has to be done![]()
As for the screw holes. Would it be possible to put spacers between the motor mount and chassis rails to give a bit more room? Only 1mm or so, but enough to allow for more material. You could space the cross member as well.
