Good looking rig! Sorry for the delayed response, been working and it's been so hot in Texas. After working outside in the heat it's hard to want to go out and play in the heat.
I used the scale VP hubs and the slw 725 adapters from VP with the VP beadlocks and tsl SX xl tires. This put it back to OEM Gom width on the narrower VP axles. It's a pretty awesome setup taking all the worry out of the axles. Use a lot of thread locker lol.
Thanks rock stacker, that’s ok no worries buddy ,I bit the bullet in the end and went for the f9’s which was interesting , I missed the small detail of the rear f9 pumpkin location compared to the stock which is opposite , my bad ..... so after some brainstorming came to the conclusion if I got 1 another front truss and inverted the axle tubes drilled some new holes it would work and holy shit it did [emoji16]
This was the Initial order
A new drag link was needed which I made from stainless 6mm tube and brazed the stainless rod ends on , yes I know they probably won’t last but I just wanted to get it working for now .
Also all links needed attention to get the right angle into the axle’s ,
Sooo this is how it sits now I’m fairly happy how it’s looks and relieved to get it working [emoji16]
I remade the bonnet as I missed a fixing hole in the first attempt and also relocated the jack
Installed the winch and ran the cables hooked it up tested it annnnnnd doesn’t work [emoji30] I did when I first tested it after soldering on the 9v battery
Found a loose wire connected to the female side of connection, resoldered and still nothing so for now it’s just for show
