OSRC
TRX4 #4 is the redheaded stepchild of the fleet. I've 3 more, all set up different (The Puller, The Performer, and the Scaler) and I've never really sorted out what to do with this one. A while back I build it as a "go fast" envisioning a solid axle truck I could bomb around the backyard with. It was a fail, the truck was just too top heavy and barrel rolled at any speed.
After reading the "why can't a crawler go fast" thread, I've decided to take another look at it. This truck started as a Sport, so it's a single speed - not sure if I want a 2 speed or not. I'm out of BL systems, so a Holmes 12t is what it's got for now. It originally had a Castle 3800 in it, and it was wicked fast. This should tame it down a bit. Chassis chopped by an inch out back and some janky battery tray installed. I'm thinking a Bowhouse might come in handy here. The 'X4 chassis is great for this kind of project since the trans has a relatively high ratio and removing the portals give a decently high gear ratio, plus is has fairly tall cut outs so I can drop the truck down a bit.
SCX10 V1 axles.... why these axles? Open diffs! If I want any handling at all, open diffs are a must. I had these on before and they work pretty well. I would have liked to keep the stock axles and use SSD portal deletes, but you lose quite a bit of width with them. These keep the width and have large chunky gears. I set it up for the longer Defender WB this time as the shorter sport WB got a bit squirrely as speed.
Getting those big pumpkins under the chassis takes a bit of work. Rear was a direct fit bit the front was a bit hairy. I put some ball ends through the axle cases and used them as panhard and upper link mounts. It's as low profile as I could get.
Ignore the Ijit in the TV. Apparently, it's a show about some middle aged loser who spends his entire disposable income on RC trucks. Found the lightest body I could and got it mounted up and it looks great imo. I went with some 2.2's, front 'Pede rims for some extra offset - should help with stability. Not set on these yet, but I do like the look.
Swapped on some 80mm shocks to get the ride height down. I can't really go further as there's just not enough uptravel with the big pumpkins and the chassis. I think the stance is ok though.
Lots more to do "thumbsup"
![20210910-105356-SM.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2F44YL5scw%2F20210910-105356-SM.jpg&hash=892b968f8bac8c09a12446802a2931b7)
![20221109-112803-SM.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2FTPTSnKK7%2F20221109-112803-SM.jpg&hash=981ad072fd28f1fa87f2e449f18ed4f6)
![20221109-112812-SM.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2FDwkRyjnK%2F20221109-112812-SM.jpg&hash=8b78818c9e60cededa4e8ee387983689)
![20221109-112839-SM.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2FtJ8w6D6W%2F20221109-112839-SM.jpg&hash=c9d004270c192aada5fc4b7a69adc05d)
![20221109-112725-SM.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2FQNzRvNzC%2F20221109-112725-SM.jpg&hash=ad432c82b7aa0ae4360dbf18f60a81d8)
![20221109-112748-SM.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2Fm2F04fxw%2F20221109-112748-SM.jpg&hash=215b5049e0f76a90c292bc0defd7a30a)
![20221109-112737-SM.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.postimg.cc%2FL8twqt8g%2F20221109-112737-SM.jpg&hash=4a8412c19b83bb811c2ca8eb1b49189b)
