I went ahead and installed the Fusion Pro on my TRX. Did all the pre-run procedures, went through the setup etc.
I thought it was going to be a plug 'n play installation like my Axe, but no.
It behaves very strange. Firstly, it seems to limit power once the throttle is fully pressed. Acceleration is normal up to a certain point, and then it just drops the wheelspeed. It even seems to stop and start again on straight lines. Kind like losing signal or power momentarily, but not exactly.
While climbing, there have been situations that I could hear mechanical movement, but there was no wheelspin at all.
So, I'm trying to understand what the issue is here, before I start tearing apart the rig. Is it a loose slipper clutch that causes this? Could it be overheating of the motor?
If I keep a slow steady pace, everything work smooth as butter.
