Vinster_Beta
USA
I don't know if this is directly of fault with the Trailmaster BLE Pro, or a different fault. I have had it on my rig for about 6 months now with no issues. It runs a Holmes Puller Pro BL 540s 2700kv on 3s lipos.
I recently unplugged it from my normal motor in an attempt to see if my friend's brushless motor was alive or not. The motor (Castle 1410Y 3800kv) wouldn't even spin a full rotation before it stopped. Then I connect my motor back up to it and plugged the battery in and it started to fry the Tamiya connector. I cut off the connector and replaced it with a deans and the esc flashes red. And then the Battery started to smoke. Hasn't swollen up yet. I have never had these issues before. Is it something with the Esc? And before anyone says it, yes I know I shouldn't had tried the motor out on my Comp rig ESC.
It's weird because The power leads on the battery to the Esc get hot and the Lipo Alarm goes crazy.
It's dead...
I would suspect that the motor is dead shorted across at least one pole.
Awesomeness, Well I guess it is time to get another Esc now, I figured it was but I wanted to get someone's opinion on it anyways to make sure. Thanks
I believe you needed change the ECS's settings before swapping motors
FM: HH's BLE pdf instr. https://holmeshobbies.com/downloads/documentation/trailmaster-ble-instructions.pdf
Brushed Motors
o
Using a Castle Link, set Motor Type to "Brushed Reversing"
o Connect the ‘A’ wire to the positive terminal of the motor.
o Connect the ‘C’ wire to the negative terminal of the motor.
o The ‘B’ wire will not be used. Wrap with electrical tape to keep clean.
Brushless Motors
o Using a Castle Link, set Motor Type to ‘Smart Sense Brushless
o Connect all phase wires to corresponding wires on motor A > A. B > B. C > C.
Sensored Brushless Motors
o
Connect same as regular brushless motor.
o Connect sensor wire to sensor port on ESC and on motor.
o This plug is keyed for installation in only one direction.
just bought the trailmaster BLE pro and cant seem to connect to the castle link, I don't see the item that is listed but they say it can connect?
If the battery started to smoke I would toss that too, puffy or not I would mess with it. If noting else I would suggest at least doing a capacity test on it an monitor the battery tems in a safe place expecting it to burn up.
I'm not saying the battery caused the problem.
It seems like there are less then desirable fault protections in RC electronics. Too often I see chain reactions of one part burning up another.
The OP is discussing a situation from 8 months ago - however we have a new post from someone else asking how to connect the Castle Link to a Castle Link-compatible Holmes brushless ESC...
It would have been best to start a new post in their case, to avoid confusion.
I have programmed a couple Castle ESCs, all you do is insert the Castle Link USB adaptor into the ESC, the micro-USB end of the cable into the Link and the other end of the cable into the USB port of your PC running the software from Castle - and it only works on Windows.
The ESC doesn't need to be connected to anything else for this to work, it doesn't need power - the LED should show green on the Castle Link itself when properly connected.
If it doesn't recognize the ESC, you may have a crap cable - or a loose connection, or a damaged/defective Castle Link USB adapter.
It should tell you on the Castle software pop-up screen what ESC it has detected, if it doesn't I'd contact Holmes Hobbies or Castle Creations.
I've done a Mamba X and a Mamba Monster X and it was a nice and easy process - if you have issues, that's what their support numbers or email addresses are for.
