fr8cture
i was a bit confused over that too.
You need two more than what the scx2 kit trans supplies. "thumbsup"Just ordered mine!! do you need to order two of the extra shafts or just one for the transfer case?
im confused over the header card showing ax31410 which looks to have the larger pin, but later on the part number ax31134 is referenced, which has the smaller pin.
i read the writeup and saw the note about the only difference being the size of the pins, but that means 2 diff part numbers not two of the same shaft. thats where i get confused.
im not buying anything till sorrca gets clarified but it might help in case other people are also confused. if its just me than apologies for pluggin up the thread.
...im not buying anything till sorrca gets clarified ...
What exactly will be in the SORCCA rules that might disqualify this chassis?
This is a T.V.P. chassisMaybe the issue is with the rail chassis designation and what ever "twin vertical plate" means.
Here is the latest SORCCA rules for chassis in scale classes:
You must run a rail chassis (for example: Bruiser/Mountaineer, SCX-10, Reign RC K2-3S, 3L, 4, 5, MFM, Trail,CR-01, UTE, etc...). No TVP (twin vertical plate) chassis' or frame rail extensions on a TVPs. Tub chassis' are allowed, but chassis must be covered by the body and follow all other scale rules per class guidelines. Anexample of a tub chassis vehicle is CC-01, DF01, Twin Hammers, etc.
AX31410 uses a 1.5mm pin and is used on the transfer case portion.
AX31134 uses a 2mm pin and is used on the upper motor mount gear portion.
...its been said on the facebook sorrca page that the toyzuki stuff isnt a problem.
if you want to troll and flame its proven that facebook is the hot ticket. please dont spark that topic here.
So just to be completely clear, we need to order one of each of these part numbers and have a completed kit trans to complete this build? Does the kit come with all bearings and O rings? I want to be ready to build when my kit shows up.
Here is mine so far. With something that VMGontherocks is gonna be releasing pretty soon. "thumbsup"
Where did you get the colored gear cases fra8ture looks great
Yes I'll have one up tonight or tomorrow.Looking good! I hope to be ordering mine next week.
Will you have a build thread on this?
