CaptainCalm
So, I've not messed with RC stuff for a few years until today, when my new TRX-4 was delivered.
So I grabbed a few of my old lipo's that I figured should work with the TRX-4. They've been at storage charge for at least the last 3 to 4 years. I picked the following (measured internal resistances from today are in parenthesis):
2 Gens Ace 1800mah 25C 2S [(10ohm, 10ohm), (10ohm, 9ohm)]
1 Gens Ace 2200mah 30C 3S (7ohm, 6ohm, 6ohm)
I've only tried charging one of the 2s packs (that I used for my Carrisma GTB) and the 3s pack (which I used for one of my helicopters and which, incidentally is on charge now).
When charging these two packs, I have noticed something odd and I can't remember if it is "normal". On the 2S pack, I noticed that the charger was reporting a charging voltage of up to 8.58V even though at the same time it was reporting a per cell voltage of 4.20V and 4.20V (when it was reporting 8.4V, it was reporting a per cell charge of 4.13V and 4.13V). As soon as I stopped charging, I put the charger in monitor mode and it reported something like a total voltage as 8.35V and a per cell voltage of 4.17V and 4.18V (instead of 8.58V (4.2V, 4.2V) when charging).
Now I understand the voltage drop after charging, the packs are old and probably need to be replaced. The thing that I don't understand is when charging, the per-cell voltage didn't add up to the charging voltage (e.g. 4.2 x 3 does not equal 8.58V).
Now it has stopped charging, on monitor mode, for the 3S pack, the charger is reporting 12.60V with all three cells at 4.20V. But just before it finished, it was reporting a charging voltage of 12.76V with 4.20V on all three cells (clearing 4.2V x 3 does not equal 12.76V). Is this normal and I just forgot it was normal, or is something strange happening here?
BTW, the charger in question is an iCharger 306B which I got for quickly charging 6S packs for one of my helicopters that have sat gathering dust for the last 6 years (yes I have 6S packs in the garage at storage charge for 6+ years and I'm wondering whether to safely discharge them to 0V and dispose of them or risk seeing if they are "OK").
