JayP
It would, but if you parallel charged packs to take advantage of the q6 power, it will overheat that power supply. So at 90 watts and 19v, there is only 4.7a available to power the charger, it's fan, and charge your pack. So that would not be a very good option. You can get the server power supplies for 15 to 30 shipped from the fleabay. You can then modify them to suit you.
With the q6 and a good power supply you could charge 6 2200 packs at 1c all at the same time with a parallel board.
Sent from my SM-N920V using Tapatalk
I won’t be parallel charging
I just want to know if that 90W power supply would be able to correctly charge a 4S battery even if takes longer.
If so, I would simply use it and decide later if I want to purchase a separate and more appropriate power supply
Again, I don’t care if I don’t take advantage of the charger’s potential power, I just want a reliable charger, capable of charging my 4S packs one at a time but reliably and with the capability of charging to storing voltage.
