UPS made a stop - on time as always! I'm like one of Pavlov's dogs...I hear the UPS truck idling out front, and I start drooling.
Anyway, some goodies showed up the the Traxxas Twins (Not to be confused with the Thompson Twins for all you 80's fans out there) I had a MicroX/Revolver combo in my Capra that I have since sold...I ordered a Copperhead ESC and Revolver Stubby to split the pair. The lightweight MicroX and Stubby are going in the Crawler Telly as it's probably the lightest combo I can put together. The Copperhead will pair up with the Revolver and get installed into something, no idea what yet. A 3:1 reduction arrived as well..
and just like that, all mounted up and ready to go. I had to trim just 1mm off the motor pinion shaft to use the GRU, not nearly as much as I thought.
The Trail Telly got some SSD brass wheel rings for a nice 200g weight boost up front.
Both were charged up and ready to roll Sunday morning.
First the Crawler: I've removed the OD, lowered it a bit, cut the tires, and installed an Outrunner. It's back in business! And Damn, it's loud. I know outrunners are loud, but this one seems especially vocal. Yikes. In any case, it's back to crawling like a champ. Cutting the tires made a world of difference in grip, but I think there's still more to be had. I went everywhere I wanted to go except the 1 hard climb... it's now my goal to get this rig up that one line. I'll be experimenting a bit with pinions, weight, and tires - I think it's doable. it's right there, balance is good just needs a bit more grip to get up the rock. Think I'm almost done with this one, not sure what else other than fine tuning I can do with it.
The star of the trip was the Trail Telly. Putting that weight up front in the tires apparently makes a lot of difference since this rig killed it out there. It still has an semi open rear diff, but it didn't matter - this truck went everywhere today. It did everything the Crawler did no sweat (it also failed the hard line test, but it gave it hell.) I'm sure the PL Predator tires had something to do with it, they were like suction cups on the rocks compared to the Duratrax tires I have on the crawler.
Cleared this gap, don't ask me how. More luck than skill!
I forgot about the servo saver and basher servo so the front wheels were a bit floppy.. the servo is pointing straight here. I drove around it, but I'll need to tighten this up.
The Mini motor and GRU combo did not have nearly the torque the outrunner had, but did fine for trail running and was smooth enough down low that I could finesse me way up and around some impressive climbs.
It started making gear clicking noises and lost drive, so I stopped to investigate... Pretty sure I blew up the GRU.
So I did the walk of shame, drove home, unloaded, tore it down and found the pinion was just loose. I feel like a idiot, lol. First thing I should have checked, I should know better. Oh well. I got 1.5 batteries through it, enough to know what to change.
Came home and ordered a new steering rack, did some shock oil changes (from 50w down to 30wt, it was pretty stiff out there) and dropped down to a 9t pinion...and that's pretty much it.
