tachikoma1373
This Is Black Four. The latest edition to Black Squadron. If you've seen my other threads you may remember all my RC's have a Star Wars theme. The latest sub-theme being Poe Dameron's Black Squadron and in particular his T-70 X-Wing, "Black One".
Having decided to start the franchise reboot with Black One: Rebirth Of The EXOTrooper I then moved on to Black Two: Rebirth Of TK-422 .
When I saw the GOM ther was no way I wasn't going to build one. Hence, Thread: Black Three: The Bear Necessity
But then I got very disillusioned with my GOM build - mainly because I couldn't get the electrics right and I blew up my ESS sound module so I decided to take a break. I'd not run my Yeti in a while so decided to add it to Black Squadron makeover and started thinking about what to go for. Some great builds on here but I wanted to try something a little different.
So Here's a little taster. The Shape of Things to Come you could say.
It's meant to be a kind of Trail/Overlander look.
- DIY panels - made from free lexan packing courtesy of local supermarket.
- Aluminum Front Shock Tower Extension on the front and Twin Hammers/Wraith links on the rear to shorten the wheelbase and get some much needed ground clearance.
- Some smaller 125mm Austar tyres
- Roof Rack and some re-styling of the RPM single tire mount for the Slash. Power now provided by a Hobbywing SCT Pro and 3656SD 3400KV sensored combo.
- Winch going on soon as well as some other scale accessories, silicone earbuds in the front diff to tighten it up and some lower gearing (when I can find a 54 spur).
