Black Three: The Bear Necessity
A little bit more progress.
started with the axial Yeti sway bar kit I picked up from asiatees in the sale. Grabbed a metal coat hanger (thanks poohsad).
y4mbLZxESCPSFs4SivGhgiWezoEoZc3hKdWy_VawLQkJUSmtGK8ipczTl85zRJ7mkxoFMzGHj0_RN5S_jnkFcmOoy07I9uKJolsmVMHY0OqrygFtKy6XnG-zdjMfFoT5FxwRtdHFsOVUuzaixHUIOxiBVDvMzbnz0Yjmid_eH_9Lg2ftCWCX3LHGMMSfacikAtJ7C266AiNTyopGy4Eh1YaPg
Mounted the winch I ordered (cable ties only at present - should be enough anyway) and remouted the front light bar.
y4mrEijYn8Vtmr86-Lw2Wk0muMQtn0lw2EmOWIbrJAplN2lobpQvLAEsj5UjFzm-A7p_egjmHcn7-V3KTQFzOIN2vjWzo9ltpr4fiY8qtvgYgmcKdAMAlg_KTJPQxYBoezAGKD78L7rLUviYgGyl6SrauilWt6zm3o9hTZ7ub3z1ynSfYcIE6qqIGbt2ToEoOuuJmVTHIK-5bPBNHVWWIzpTQ
Sway bars mounted and mocked up the rear again, still work to be done - hoses, fuel filler, fans and the light bar to rewire (outside will be red middle blue/orange flashing possible linked with siren operated via extra channel on the ESS module).
y4mzFOKnBx38LJCmgjBSkhUJAnulVsHTAvlaRY4UlGX9B_BPvIJHkSuyWm1BEMre0xaef0eQkr8A2qibBEkw1UmPUnFwJIb2Al0J0vuH95D_e7tjd4pnW89HCnUdWr0VRLmcSz_k0KVLqsMxUV-JdhBI-HCsKzMw-mAECSDRLIMgIPxWp3-Q4JrtOSSK10I_RtmTkNnFfE5icxm7-5vc_Whhg
y4mH7scXnVd_xsxuIFglEPzX91wgK5UCvMvbQTtglH8i0wqJ6EqbxPCUzNBxkexjxEq4Ck4M20VaHtgbkeyS1QkROC-BWzIZQn1i4UErozxH7UCAw_MUSkhzv-Pt4xxkzH0km_dEqJ0CCGUUvXNfML0nZUEqh39Tb-4yzksnxG6fVi5hMZCznypgnCrLYj2x2m6WaF0G6DvybsaWSnIXbg3Eg
And the wheels for my trailer project turned up.
y4mOk1k8XDxgXG1OyG-sl2Ct36tY-oh9pfz1RJf9LJiv9XRFKGGAgzU8dAkleXCTHO8QeCXITcWkYtDtD0PHlI4WJVE5YMHDnWATAJ1hZ0AGYqRLAhgS1iAx4jbuGVMPtn_KsFGmWqjVLDxvwC85L22FKy7RYIehMlPdaJP5YWx3TiwGB1KGBdL-NgXXLvnS3OiUwyt_L_q16lFQiM66NW4yQ
Progress continues at its sllooowwww pace.
I did some finish up work on the rear. its not brilliant but I'm happy with it for now.
y4m7NhdEG61_AuZPQz_cxH4hiybjiBdJZZ3DojTycQ5BQeOC8VeIrY6AJQLHoYCsmRJXLZhni9gtpJG0L5B-xCSRc8DHGugiQjL0uOqHg96BB0BUcePRBSH_WHMX8zTGCOyL9zBdELCyV9E_mz9cTZuAB414-0PtddsSICTy56tx56cxGbvg2NMZm7wqBYedeg0kbrHbV4GJePEopiuydGJ3w
For anyone interested the "air filter" is a tipex bottle, an ikea mirror holder a short piece of black coaxial and some cable ties. the fuel pipe is coaxial again attached to a butchered 3.5mm right angle head phone jack with a couple of brass rings from a damaged servo. Fuel pipes are a couple of PC crews and risers with some thick copper wire. :)
I was starting to look at the electronics and realised I wasn't going to get everything in under the hood without cramming it all in and running the risk of overheating due to total lack of air flow. So I decided to make the GOM a single seater with a little box that fits in the cab for the electronics in particular the receiver and light controllers. I started to assemble using plasticard and some mesh. The lid will lift off for access. Only the ESC and motor and winch controller will be upfront
y4mDo1o45BkWJQH0vkORnzeBC5qg1ST4pv919Kv3gO0_W7wBWrD6SjZsNB19bz6KeNR4g6DnEVRFgker1w7XFCWU_yNSyGIbebxCGbqoReQSXYihQ9a9xv1mweUBONw3tZwLpyLHygmhF21nvv2FJ24aYnIUnz8wnn83BjK8dGGxwgmETP_zpnjYvQDPSv1TGdl2Uz2yZtDlBevFF8tafjJ2w
y4mUk02N4TklKLI26cm_O0YSu3a87OYSGysFfEC3yfL1BQYZxdBV6tWOYdxkjTFnT3QeEMinrqTCob9zxmhSUgJCdqDNXhiQ7oObYmUJGpV2o0PS55d5vTV99lPsBB41AidiDs5OImf_4Rd7VmvEYcKrqRr401YOboYIlOfzUiJiQWf0P535sbiJEQWHOebdwkbLeq5Za-_EFCaoNXpX5O_SA
The dual shocks with piggybacks thing isn't going to work with the shocks I bought (as previously mentioned) so gonna go with the stock ones for now and try and get this thing running in the next couple of weeks.
Looking good.
I hate to even mention this seeing as you've made an awesome little electronics box already but If you plan on using a shorty battery there ends up being extra space at the far end of the battery tray. Thats where I've put my receiver and bundle of wires, lol
The trailer looks nice too, looks like it will be fairly lightweight which is a good thing. I made one around that size and it ended up weighing in at around 10 lbs.
Oh and where is that driver from?
Looking good.
I noticed you and others doing that and looked into it but decided from an accessibility perspective this might be a better approach and something about the single seat thing in ultra 4 cars got me and given all my others are multi-seat. I dunno, just one of the things - you guys know :)
trailers on hold for a bit whilst I figure out axles - got some bolts to mount to the side but its just too damned ugly a solution for me :)
I tend to use Star Wars black series figures (6") for my builds - being a fan and all :) I'm not set on Han as the driver yet. I really like the way Poe Dameron in the Xwing pilot outfit works in my EXO rebuild (with bb-8 of course) - its the orange of the outfit - again you know how it is sometimes when you just think - you know what, it should look like this.
Or is that just me? :)
With my Trailer I used Axial Wraith dogbone ends with a mishmash of bearings I had. One small bearing was pressed into another so that the outer most bearing stack is the same diameter as the inner most bearing. I then used some stainless metric tubing with the same inner diameter as the bearings outer diameter (which was quite a challenge to find in the states) to house this assembly.
I welded these metric ends onto a skinnier bit of tubing so I could fit U bolts around the axle for the Leafs. Then I very carefully applied CA (super glue) with a tooth pick to the outer edge of the bearing to hold it in place in this tubing, they're pressed in pretty tight but I needed something to prevent it from loosening.
Its been a while.
I got really disillusioned after frying my ESS one and switch to doing something with My Yeti - see here The Shape of Things to Come: "Black Four"
Anyway I figured having had this for a year and still not finishing I better get it done before I start my next project :) So I did a bit more work, redid some of the accessories, new 3D printed fuel cell courtesy of " G_Factory" and I did another 3D print, a GMADE GOM Motor Cover, designed by "rockracerc".
I hacked a chunk out of the middle of Chewie to make him fit. Of yeah, and cut his feet off like some sick drug cartel like scene.
Had to hijack the Gmade shocks off my wraith as one of the shock caps is split - me and my fat fingers. Will get some replacement caps
I fitted a Flysky FS-BS6 Receiver to go along with my new FS-GT5 Transmitter (which I recommend) and use for all my rigs now.
Transmission is on CH4 (3 position switch on the transmitter grip)
Front lights, dash light and rear lights are on CH3 (2 position switch on the transmitter grip)
Roof lights are on channel 6 (dial on top of transmitter)
I plan on adding a winch on CH5 at some point soon. That can wait for next asiatees order.
Added a couple GT power switches, one runs the front light, the dash lights, and the rear lights (2 x red solid, orange and blue flashing) that run on channel 3.
Not run in anger yet but transmission switching looks all good.
Anyway enough waffling. here are the pictures and a link to a short video.
y4mB_vJQoM45Ofl-CAWW7Dx059FYItDSrpefCg74KYCLtUFUXtDMO7RrchVhMQ2Iazof0adzAX2gC6LeFueU3YtDIlmGq0LZxbF7Bf3GH-MN0TD6NGntZyXYNbLiucTwPFuqTRT-XW0dF5K-8erwx-bpHOERZJNXrHeyCCdjTEF9hUYTrDWgHdtyHQyX1N6XplXyCb7ZdjgaMYGdj_ITt5YUA
y4mOkqMdPIEjBzqJ9Z3xx5JNsIoDFfAXvAUYoCkF9OdVTFjOUD-Wmt9EgjzPSZKQYkFly7DuHykOhiGv2FBFD5ENmommmrP_1Uc0a_Ng9zGTVI4L4ELTqGq2skgpkKCwlKdM9IMnvZoyJCGWFxDZo7YjftB9h1xRz74fWJCuPBu1QV21A_hUZK6maCL9uuaKI7XcieKxjOjEwC5QuRHVr6qAg
y4myxxK0zrhrMlGIi5GB_hPSS0nGxl-uFeaoSuxqoWpK5bhfTKV590W02QZj9a_u3dElHxhQZ-AYIWTYI_JZPn-sV-lU7Kp7100psAixNMKOZQuZn97F7LkM_nYfP8fKP5FqjyGoZV8KYp9tyQu_HISa1kAZY3wTKbBSCF4NoLzZuGbCO2DgZB6eh-AeiTm20AQl7E2V6SmfHHebYcVmbvWJQ
y4mSYhQXbY_jm6xTvcMFEf1EnShI89VN9WtxtDpo4sNqkfZKl3x0XXJlKw_dPgE2aPatzTastP1rxOzghCbL6QXf6WHpjUXS9EZRTeA1XuxpuSrPLcpL9Xp06r89QEqDAl_HtkxYLTQIiZfwTGFc1YN0tj9LCh7MchjIdMwJjCot9apq78sIxNH_5llblAxo8p1MAWJ9iZEM4hYq-jHKbGwoQ
y4m_mSZgDSZFF095OPFiZQ3s-W5r_FoQg2FUbXfZM0wcGURkp7xfMUYWcZ2MUuGGbNFzEkpU92GPyyf8RDuyHFiTLHAOqkdNTUU_en7oOsNtTVcP7uZBax7JgxQhX4pHRrue4nZErvuFAkZhgdrvqYl6FXoyHYnVDOyRM6PJ5CJ4qa7UD6DEn-3Etz1mBuvhWCcnik9A1RSQzmScL8aSrxwwg
y4mmmF1Ud8lCqk95RNjCo1e815qLpAxsUTKdbRCHHwjI62UoGtirZBoPbxcKkvP5_Wav69clkHlUjxL-Wu0OroDRteJddQIaSxoQQYrN7lq3OmcIhVUydf7h-92s0cx-QhI0YN5WAThR43AZ948-DpiP-k0bERKqxLAGQRJs8RHnygD8-yQEJZHutkisjdeuj5yS3XgbZr-5GLXZl_ZsgQQhw
y4mzESlrHjsgqsf8-oSd8EB5w9OBtB_XpSMSach-dUKR6kVXCbR8_CvTP0J4WooWyWJ6RQzEIWVvsWDWYOWgB72ZzgVVprHDqS7mPewhdTR92dNzFsClndyDz9LnZGKI706qlmouKoOHfIOZYuJn1EFgf1PcMnhiS7ZpB-kLIWQKdTC2KjaNvriTe9Q7-ruOLtFIQtFCxk5o0qQbjVUA9O9YQ
y4mtfme2xOHP6uNnkgCgp9TUm8Q3MOdpy9vpVgrKHRaLflXsAj3W5xouOdV4y9JoLJpuWvSRTX9Eo0ZFKfinPSp142oK84K3YmLVMeW0t0vZpgGF1xMUzsuzmMrOGgF5XVGoZmVc0g-jPsLv-v7yrO8bGgb2yi3XV_rYHkyhp93CUMfGnwihwUM1c0rbx0iQfdZecJUGr7coLwAQ2tO32yh3w
y4m6603pBnhTt6GiCAXWe58RqminInPdCVjWotzf_sZRrynLN-rS-H23VtqGonaJT8eK9wePnh31ZgPIlC7pWrZ5SJyL8bQPIzWf8CqbesbWLUQsSTEhRB5IDiH1YQtaZkEeet-UMf9XcqkNO5gBdJzhiln_PCjTRZWa9_y7j-vDGoSvc7VzL2eomrE7ND3T8oVxGLKWt0h2jv0xCfdRqaxYg
Video
So this happened on the very first run out....
y4mKZqHk829XX8qP8cpSFnu1H8d543IghqxYCnGSO0a0ZFZg8zqn3InaCA-eAcWah9R0MIDb5i0CoL0s7XDE1CH2y2o3NICDxXLB1k1GuWRp5lPqdC2rVyZYaC0MfqtQeYP7A33Rb3acUYxOrgBsW5ML50tzYhLUM-uLw8hJEry74qDubrn5KLk5nCl6v6-EdFHKs1sZCqTEgFZCnrx4HiOwg
So I decided I wanted to tighten up the front end and I also noticed a lot of play in the hubs/wheels, etc.
So bought some 8mm (6mm internal) steel capillary tube and got the grinder out. Ignore the dimensions written on the paper as that was prior to fitting and some tweaking was needed. The proper dimension are:
short side - 53mm with groove centred at 29mm (from the left end)
long side - 96mm with groove cantered at 64mm (from the left end)
y4mCYiDMEqMNGWBo-sNFLh_yxrXTDxXj0qpklCH18Zp_Mkoh5omojDfd8C5OAbY6ThqxYCBRROX481H74VuP17IGiVpFNg1Ih_MwqmrBFG5Ew__bjGbP_vNyz07Pq66xFyViMju_fLAeICj7XluMX8YLe8TlEY768UsBYqSF3XHtvBaZKhSXFEYMuDw_DA0FLy6VKpFOjQPF1F_wIz3TUKPIg
y4mFxnJ2hdKtW1tR7tvc3ihk11i96en1tFicOB6I50QGJklzJPL9R7UDmJUe5OPXBMNPzKEYPDzm8uVxzhLefRQzvdWZolHZ2Q0OSmaaSEuy37WSjGfG3KZ12HMgbICtJPCbh6mYAFRXglNNPGILJS3UcYvplI81YwE4Ue0X73jm3lqBJIkPSXacrw_W-t38dkbK8S3l-pAMSUVq1xRSgKchA
I fitted some shims and rubber rings to the wheel axle shafts to limit play. Front end is a lot more solid now.
y4mCUKt756hjmtK1aTzYbFBz30Mzo-kAz6gySQOP2MBymskxyFSTwD38jCIMcfNMPZXAQd0_IyMbpUTeUj35qKNk5tTrh_GAz6RihwH83C7FdB38HlCXQdDzwhE220vq3AcwFMUXrkJO0DMKczRkW8cZ4Z2iehq2JBpY9nqDSKucV35OcNZ_MA9-PvDZ3QjxqLTeRSNu9AYmNaTtW3Hfebw0Q
y4miZ_lT6P4DardDdVdaZkWLIkfe5MqeP6-hueM37JwB90YZEEfdHYoCe4gVkwtVVacwckFC1YY1A8zjbcvLqAfUztPlRx0EB6Jk3cXlk0fCLMicLiTVaLWYE38fEhQIZ88MMbhqU0bJbPv62OzQ2BQAix7zh_IBrOmuhL50xkz1D6n8J32MjMOfXqkMYBfe20zqVUEvTw8zc21agHJbUn8jA
Also got an ESS one dual to fit. Then its back out into the wilds for some photos and videos - when I get some time in the daylight hours anyway :)
Almost there now. Fitted dual shocks using a set of team raffee 110mm with a changed 3mm longer end, 20wt oil, top hard spring, bottom soft spring. coupled with stock shocks and oil
Out for a spin and a photo shoot this weekend hopefully. :)
y4moLtVGI4UYzbhnf8sPVm5VGfKvvnJ8V_HaNWlJ3Qa94TbpIAWpuLWtOnoBaBhJ6kdDH7ycPQzh-MmKfa5I1ynyRCLEVQUmWVSw2-1QgmRU-14Bk4Jfoftd_Ig07nKleBZvi6MChdjQP_RoTKxpeabvqU3YxVLSxW-Z26AFmPtc1pamHwNSaz29Vgxc0HDMy1mtwfspRkWUpwemBLCta2hfg
y4miCyTw7rZQyRddAO7_FKyalNSOC2MIcUbkdfQt6RezQb_SmL4lfsH40aOVV-Gzy4u86BSIM2Tp2YUtUIIKH0aOBDNEEw0Hw2b_XqTMyCK8Faiy78L3dShhTKrjJbRtXfSfokO6WH9AtbuyWHBNEDushqwIlvSeaZxl7KW0QnSCE4c2OIlJEvqs4nI2SVM8x1r6GJzWeECZVCJf7-Yp8t4Qg
y4mqMm70NgwezIl7NxUB94F5uKgzpmYtU99B_6UXwYqL9uD5zSVwNd86Xlux0bTkGsV5HzoqMi6xHWa5vOoB_DJGrgcOMapYPajyF3iYkGjc6SVrTAPX4SqFpD0nMEDf8PvEpZyJ_WARJpLBlUuTnjlJLqNw2O_ywWf4Pf5n70GLPCaRgUEQGwoTz40Ta6A9qiGZJKNwrQAJM9zipKF8ZsyFw
How'd you break the front axle? Is your weather cold right now? I have the CVD's on mine as well, but I also bought some Axial Universals and will try the modded Axial Universals that someone else on here did when I have time.
Unless I missed something whilst driving (which I'm pretty sure I didn't) that just down to one jump where the gom came no more than 8 inches with a perfect down slope landing, no funny angles or anything. The temp has dropped here but it was still a few degrees above freezing.
I think the issue is the length of the overlap between the hub and the axle, the fact that its thin plastic, and it has those grub screws through it to hold the hub on. I'm toying with the idea of putting some epoxy in the small gap around the outside of my home made beef tubes between them and the inside of the axle housing. Hope that makes sense?
Hi, I wanna start by saying awesome work! I have a question about the Team Raffee double spring shocks. How are the spring rates of the included springs. I know they come with soft, medium, and firm. Also how well did they hold up to use. I know this is an old thread, but figured I'd ask anyways. Thanks.
Sent from my SM-A205U using Tapatalk
For reference I plan on using them for an SCX10II with a Yota hardbody I'm currently building. Thanks again.
