The Rock-Clod Gallery: A place to post u'r clod in action!
Here's mine.
Homemade chassis/servo mount/link posts, 2.2" Masher 2K's/'Pede rear wheels, Integy 55 turns w/13 tooth pinions,
Super Rooster, HS645MG servo, 12.5" wheelbase, Maxx shocks and Maxx turnbuckles for links
Finally feel like I've got my Clod "done."
CX2 chassis, Lathe motors, Super Rooster, modded TQ3, 6 cell GP3700s, HS-645MGs, PL Commando Beadlocks narrowed 1", PL Moabs, Bender 23mm adapters, RC4wd alloy gears and lockers, CMR adjustable motor mounts, 9t pinions, Powerline Tmaxx shocks.
Only other thing I'd like to do is TTR CVDs.
And my driving skills are slowly coming up to match the capabilities of the truck. :)
-Jay
Sod Krawler
Home made chassis and links.
Traxxas rod ends.
Hot glue locked diffs with bearings.
RCGuy C braces, adj. motor mounts & 8T pinions
RC4WD upper 4-link mount and skid plate.
Integy 55T lathe motors.
Team Orion stick packs.
EVX speed control.
TQ3 radio with rear steer toggle mod.
HS-645 steering servos.
Traxxas shocks and rod ends.
Stock wheels narrowed on the inside, stock tires.
New Bright Raminator body.
My clod is always changing, but this is the most recent version.
16" wb
No-link design
stick chassis
Behind the Axle steering
Independant front and rear steering
Tekin Rebel 2
(2) HS-645mg servos
Integy Lathe motors
8 tooth pinions
Inetrc Clod axles
Inetrc differential lockers
Novak Xxtra reciever
JR XR3 radio
XTM Thorn wheels
Proline Moabs
Ace's wheel adapters
Proline Rock Pleazer body
Here are some pics of a set together.
1 link suspension
16.5 wheelbase
Super rooster
TQ3
Corian center skid
Spring steel steering links.
The Mountain Goat
she crawlers like nobodies business
18.5" wb
5.5"gc
55t INTEGY lathes
EVX speedo
TQ3 with my rear mod
home grown chassis and high clearance links
15KG servos
Here is a pic of my first clod crawler. I made the chassis,4 links,front servo mount and rear steer lockout. The shocks are some i had left over from my t-maxx. I cut the clod wheels down with the stock tires.I have to make some longer upper link mounts.I'll be switching the gravedigger body out for the bronco body soon.
heres my clod
stock chassis, front locked w/ 10t, rear locked w/ 9t, super rooster, 55t lathe motors, white duct tape keeping body together.
my clod showing off
rock bull chassis 16"w/b
narrowed moabs
integy's 55turn
novak super duty
and a picture of my .21 conversion EMAXX
My Clod Project
This is what my Clod looks like at the present time. I decided to use my old Clodzilla 4 chassis and go from there.
It really acually works pretty well, though it probably would have been easier just to build a new chassis.
Moab XL's
Super Rooster
Integy motors
Independent front and rear steer using a Futaba 3PDF FM radio
17" wheelbase
Finally a worthy picture (GASP...on rocks)
Finally got a few rocks in the back yard to play on. Also new body and different tires. The Imex tires just werent sticking too well.
16" WB
NN chassis
RUbicon body
clod axles
(2) 645mg Hitec
F&R steering
TQ3
Narrowed Velocity 6 40 series
Moab XL
cheap 1700mah
SUper R
8 tooths
Mine
Here is mine built on a stock Clod Chassis. I saw all of the tube stuff out there but wanted to try something different. It works very well. I just need to lower the CG more.
