The Rock-Clod Gallery: A place to post u'r clod in action!
This was very difficult.Here it is.
2.2 Clod Smurf
Any suggestions would help. Havent played with RC in years. Ive been playing with 1:1 crawler.
Locked Clod axles with JB weld
Custom chassis and links
Clod shocks with soft springs
OG Clod body with bed bobbed
65T motors (in the mail)
TQ3 (in the mail)
Traxxas Agitator wheels
Losi rock claws
Crappy steering servo
Crappy dig servo
Here's my Clod axled Super Tuber! Still testing and refining, until I can afford another ESC and 4-channel radio gear. Tube is alloy from local DIY store brazed with 'Durafix' and home-made Delrin skid. Drag brake sucks - need to get better motors...:x
ESC: Castle Creations Mamba Max
Motor(s): 2 x Novak Crawler 55t (wired in Parallel)
Servo(s): 2 x AceRC DS1015 (with Castle BEC)
Trans: Stock Clod. Locked with JB Weld, (now has two billet alloy gearbox cases by CurlyPaul)
Axles: Stock Clod, Alloy knuckles and Yeah Racing 17mm wideners/adapters
Shocks: 100mm Alloy, adjustable with soft Thunder Tiger springs
Tires: 40Series MOAB's on narrowed Axial 40Series Beadlocks
WB: 17.5"
Diff clearance: 2.25"
Center Chassis clearance: 4.75"
Rockbull v3
Mod'd TQ3
Novak Super Duty
55t Integy's
1" widener/adapters
Glued maxx size Mashers on dyed Proline Velocity 6's
Dual 2400mah batts
Here it is after mocking up the narrowed axial 8013 beadlock 40's and moab xl's (soon to be dyed)
*yes I know it is too wide, narrowing and milling the 17mm hex on the wheel adapters this weekend "thumbsup"
Here is my CLOD but it is not ready yet,still waiting on my servos to come in.But here are some pix..
hers my RIG in the beginning stage
The Burb
I've already posted up pics of Big Red, so now I'll post one of the latest project....The Burb, a mix of some stuff I had laying around, and an ebay find.
17" wheelbase
15" track width
TCS NN chassis
Integy reservoir shocks w/ white soft springs
Run of the mill solid link arms w/ traxxas ends
Hitec wuss servo
Thundertech servo mount w/guard
Aluminum gear cases
Integy axle tubes
JP Customs knuckle pack outers
Thundertech 8mm cvd axles
Integy gears w/ lockers
Adjustable motor mounts
8 tooth pinions
17mm adapters
Moab xl's in front regular Moabs in rear
Narrowed Axial beadlocks
Super Duty esc
Mod'd TQ3 rx/tx
Basher nitro body
Project Clod Crawler
My latest project...Homemade stick crawler, unfortunately it is still in progress.
My Super nicknamed Big Evil
Unknown named bodiless chassis
16inch wheel base (may be changed later)
sleeved susp. links
front and rear steer
CC BEC
moped v16 ESC
locked clod axles
2x integy 55t motors with 8 tooth pinion
40series moabs with 40series beadlock wheels
upper and lower link mounts and C-hub braces from RCGUY.com
2x 1/4 scale hitec 5745mg servos w/ custom vertical mounts
integy axle/servo mount braces
trusty big bore traxxas shocks w/ savage shock rod ends
Elite 1500 mah battery (axle mounted)
Modded TQ3 tx and rx
Now for the good stuff:
Started life as a clodbuster
newera chassis
hitec servos
novack speed cont
55t motors
tlt wheels
Integy axles and lockers
Integy Spring Shocks MSR10
Futaba 4 channel radio front and rear steering work ind
lots of hand built stuff
Ive had my Clod for some years now and now want to make it into a crawler. One of the ESP frames(an early one I believe), ESP F/R servo mounts, stock cans, gearing,Duratrax shocks(I told you it was old), but has full bearings, and RAM lights(front)
Here it is with my Wild Dagger(I still have that as well)
