I've missed seeing the de-marlinized Marlin!!
The new bumper looks great! Sure is a ton better than the stock bumper that would get hung up on everything. I'm glad I removed mine from my Marlin.
Shackles look factory and I like the scale bolts holding on the plate! Excellent job!"thumbsup"
Perfectly shaped and proportioned little pusher bar... "thumbsup"
Looks as good or better than what's offered aftermarket!
Yeah that’s awesome, nice and straightforward. Sometimes less is more
Good looking bumper HPD! thanks for reminding me I can build my own bumper rather than not having one because i can’t find it anywhere lol. Sometimes I get caught up in just buying it I forget I have the ability to build.
_________________Veterans deserve a whole month too…
Thanks very much! Quick story that we can ALL relate to... After everything was finished, I started reassembling it in orderto finally mount on the truck. And the very last step was to install the license plate. Holes for the little 2mm bolts had been tapped/ pre-threaded but I guess one of the [pre-cut/ shortened] bolts was a hair too long and as I was tightening it down... 'SNAP!'. Bolt broke flush with the bumper... S#!T!!
I was so furious that my mind just went blank... I got up from my work-table, smiled, and turned out the light in the hobby room. My eye was probably twitching tbh lol. But I gave myself an hour or so then went back to it and proceeded to use the smallest Dremel bit that I had to very carefully and precisely grind out the broken piece while making sure not to accidentally enlarge the hole or damage the threaded portion of the hole. Man that was rough but I got it cleaned out without damaging the hole and without any collateral damage to the surrounding paint. Cut down a new bolt, threaded it in and done!
_______________
I have bins separated into 'metal', 'hard plastic', 'soft plastic', and 'foam'... just scraps of whatever stuff I might need. I really like being able to make things without spending additional money.
... sometimes it's easier just to buy!
Nice looking truck bud! I have wanted to make my own metal bumper for some time now. But the organic bumper has grown on me soo much I don't want anything else :lmao:
Thanks, man.. although tbh I have no clue what organic bumper you're referring to. You make one out of wood?
Man that's pretty slick... fun-looking trail, great color on that rig, and REALLY cool bumper. Good idea and we've all seen full-size trucks with wood bumpers so it definitely looks scale. Thanks for sharing... I'll have to check out your thread.
Getting back into my 'slightly de-marlinized tf2' recently. Currently waiting on a new motor ( Crawlmaster Sport 550) but figured in the meantime, I'd address something that's been on my list of things to do for this rig for quite some time... Making a new front bumper.
I didn't want to buy one because of the expense as well as not liking most of what's available out there for one reason or another. So while what I made isn't perfect, I feel that it's much better than the previous one. It doesn't match the rear tube bumper but I'm over the whole 'matching aesthetic' thing on this rig at this point.
Main issue with the previous bumper was that it just stuck out too far and got hung-up on sticks and things. Obviously it compromised approach angle as well. It looked cool with the pre-runner appearance but it was time to put something on this rig that would improve it's performance rather than hinder it. The winch on the old bumper wasn't functional anyway so... time to go.
New bumper I made from 1/8" ( 3.10mm) steel bar stock. Nothing fancy and I guess that's obvious from looking at the pics lol. I used an old bumper mounting bracket from a no name chinese trx4 bumper that I had in my traxxas parts bin. The shackle mounts are actually modified aluminum body-mounting posts that I've had for over 20 years and never used. Just had to drill the [body clip] holes larger to accommodate the shackle screws. Pretty straight-fwd besides that. Paint is self-etching primer under Krylon High Heat satin black.
@ diggerj - Thanks much for taking a look. I haven't gotten to run this rig since making the new front bumper but hopefully soon. Unfortunately, 106 degrees is just too danged hot to play outside for very long lol.
Been a while since updating this thread. Not much to add but might as well keep things documented at the very least.
>>> Installed RC4WD front fender liners. Made from quite possibly the thinnest most flimsy lexan in the entire universe. Not a big deal for a part such as this but definitely worth noting. Also worth mentioning that these do NOT fit the Marlin Crawler with shock-hoops in the stock location. You really can't just lower the mounts without some major modifications so modifying the fender-liners is about the only option. You could leave enough material along the bottom of the liners in order to mount them high enough to clear the top of the shock-hoops but I had already cut these out before realizing that. Not sure that all makes sense to read lol.
I wanted to keep the shocks where they were, so it was time to break out the Dremel instead. Pretty self explanatory.... Just have to cut out enough material to slide these down over the mounts as well as making a cut-out for the top of the shocks to clear as well. They look fine and they do the job of blocking out the electronics inside but again... these pieces are pathetically thin and flimsy. Fwiw I used Krylon Fusion satin black and painted both sides of the liners.
>>> Next up was motor replacement. After corresponding with Holmes Hobbies I decided on the Crawlmaster Sport 550 15t. Gearing is the stock 14/ 64. I have some reservations about this being too much motor for this application but I'll give it a try and see how things go. I can always use this motor in another rig if it doesn't work out for the TF2 and at only $20 it won't be a big deal.
Pretty straight-forward install although I did replace the cheap RC4WD connectors with the much more robust ProTek 3.5 mm gold bullet connectors. Night and day difference with the ProTek connectors... Very happy with these.
I'll definitely update this part of the thread after I've had a chance to run a few 2S and 3S packs with this new motor. That's it for now/ few pics...
Original RC4WD 540 45t next to the new HH 550 15t...
Old connectors & new connectors... no comparison...
Installed and ready to go. Also you can see in this pic the RC4WD fender liners and how they had to be cut out in order to accommodate the shock hoops and shocks.
The fender liners are the thinnest lexan I have encountered as well. Worth noting, I used the Gelende fender liners, which will fit with the Gelende shock hoops, though they aren't as round as the ones you have. I was ale to use the rear fender liners too, with heavy trimming to fit under the bed. I used Plasti-dip on mine.
That 15T may be a little much for the TF2; I find at times the 27T I put in mine to be a handful in second gear :lmao:
Awesome little update none the less! Trucks looking good!
Yeah... I'm not sure why HH recommended this motor although a lot of people say that it has a a smooth controlled throttle response. That was why I chose it over the trailmaster. But yeah, maybe a different size would've been better for this particular rig. We'll see.
If it DOES wind up being too much I'm hoping that a different spur or pinion might do the trick. I'm planning on running a 2S in this rig... not sure if that will change much though.
Btw I would've rather used plasti-dip on these liners too but had to just use what I had on hand. I've got too many partially used spray paints already taking up shelf space lol.
Thanks for the advice and for taking a look... appreciated.
Rc4wd fender liners are a joke ... lesson learned though I did reinforced them with shoe goo and a piece of styrene at the sidewall mounting area and they have held up ... if you mount and dismount your hardbody regularly they will likely not survive long.
No problem bud! I too try to use what I have on hand, and that's lots of PlastiDip cause I love the stuff! :lmao:
I wound up just changing the forward rate lower for mine, if you have that option on your Tx it'll probably be easier than another motor swap when you get to that point.
