Gavin Ayala
"The Gatekeeper" A AMW Built AR60 Axle'd,Gatekeeper Chassis , Activated Outlaw
I built this Gatekeeper from parts sitting around the C.I shop. The chassis is a Gatekeeper delrin prototype and skid. The chassis already had these AR60 axles with links and shocks bolted up. I am building this Gatekeeper for Activated Outlaw rule set in the Competition 4x4 class.
I first got a Dlux Cheez berger and I wanted to use the opposite rotation driveshafts and use the built in overdrive. I bolted the Cheez berger up to the skid with no clearance issues. I then flipped the front axle and made a 1/8 delrin truss that holds the servo, esc, bec, battery, receiver, and upper link mounts. I bent my own titanium steering links and made a rear axle 1/8 delrin truss for parallel rear upper links. I built Traxxas 3.5 big bore shocks for the front and rear with 3 hole pistons and dlux spring cups with mini t springs.
Build Parts:
Gatekeeper Prototype Chassis
AR60 plastic housing
Front axle aluminum tube
Front axle overdrive gear set (passenger drop)
Rear axle underdrive gear set (Driver drop)
Dlux Cheez Berger Trans
Traxxas plastic driveshafts
Traxxas 3.5 big bore shocks, 3 hole piston, Dlux spring cups, mini T springs
Titanuim links
Electronics:
Futaba receiver
Hitec 7954SH servo
Castle Creations BEC
Castle Creations Mamba Micro X ESC
Castle Creations 2280 KV sensored motor
Running on 3s 800MAH lipo
Tires, Wheels, and Foams:
Voodoo pins cut, narrowed, and shortened made by Nova's Ark
Crawler Innovations 6 Bolt 1" wheels
Crawler Innovations triple stage prototype foams
![45130340202_c7cecf4867_c.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm2.staticflickr.com%2F1937%2F45130340202_c7cecf4867_c.jpg&hash=6cd7f3342497c0d430d19986818c99eb)
![30240820427_02e731c029_c.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm2.staticflickr.com%2F1927%2F30240820427_02e731c029_c.jpg&hash=523a5fe3d44503d85ab7ecda0dc31c9b)
Build Parts:
Eggressor knuckles
AX10 chubsDlux Cheez Berger Trans
Titanuim links
Electronics:
Futaba receiver
Hitec 7954SH servo
