MikaelBerberg
So I initially built myself a Bomber with Wraith trans and WB for class 3 in Norway (flat rails not allowed in class 3 there), but that was way too huge and wide for that :ror:
So when I came across a Capra cage, skid and links for cheap, I jumped on that deal.
This is the first revision:
- Capra cage with InTheWorks flat skid
- Grey SCX10II 3gear transmission
- TMaxx rear driveshaft, wb8hd front
- Capra lower links with Jato rod ends for longer WB, homemade upper links
- Dravtech Medium shocks internally limited 5mm with soft front springs and medium rear and Trx8351 caps
- Holmes Puller500 13tXX
- Castle Sidewinder Micro 2
- Holmes SHV800 front servo, SHV500V3 rear servo
- Futaba 25mm servohorns
- Sanwa RX482
- 2.2 Crawler Innovations 6 bolt wheels
- 5.4 Proline Superswamper SX with Crawler Innovations soft front and medium rear foams
- AR44 axles with AR60 C hubs and china brass knuckles front
- Stock short side AR60 shaft on one side and cut long AR60 shaft on other side
- Boom Racing Overdrive gearset 27/8t front and underdrive gearset 33/8 rear
Pretty heavy cage
Some dremeling was needed on the skidplate and transmission to fit inside the cage
With heavy wheels and light axle housings, this was the first time on the scales
Some training sessions before comp season (5 months ago now) :ror:
- Sanwa RX482
Pretty heavy cage
