ardinmcallister
I love my capra, but honestly I was just getting so bored of the cage look. So I decided I was going to rebuild it with frame rails and a real body. Little did I know that in the end I would customize nearly every single part that was printed for the build.
Shoutout to Tinkercad, because without it I wouldnt have been able to build this at all!
Here's what I started with.
Not too bad, no? It performed wonderfully, it just got BORING.
So I picked up a set of V1W chassis rails from Spare Time Hobbies, a pack of printed parts for a capra build (Optimus 3 build), and the STL file pack for the V1W.
Here's where I ended up. I spent hours in tinkercad modifying already rendered STL files, but I'm so proud of where its ended up.
Specs:
Crawlmaster Sport 540 16T with a 11t pinion
Hobbywing 1080 running 3S 1500mAh lipos
Jconcepts F-250 Tucked body
Spaz Stix Sapphire Blue Pearl over black backing
Integrated DSM Recovery hook
front end stretched out with Jato rod ends
Samix brass knuckles and portal covers up front, just portal weights in the back
Injora 35kg HV servo for steering
Amazon 35kg HV servo for 3-position dig
Green springs all around, although I think the front could handle a little more stiffness
Injora "Austarhobby" tires with a messy combination of foams. I'm using the red ring from the Injora "dual stage foams" and then a medium hair donut on top of that in the rear. I'm currently printing out a TPU ring thats hopefully more flexible than the red ring so I can use it up front with the hair donut for a more "squishy" front end.
I also designed that roll bar and printed it in TPU. At 100% infill, it seems to flex just a little more than nylon, which is fine since I cant print nylon yet. I'm thinking about making an exo cage for the truck body using the same TPU, just because I think it might look cool.
Now I just need to find somewhere to mount the plate in the back. Thinking about hanging it off the roll back with a pair of zip ties
Two more action shots, just cause.
Specs:
