Alright So I promised you guys a comparison and while It is raining outside and I could not go outside to shoot video I decided to see how alike these motors are. Beside their obvious KV difference of course so ignore that. I took some pictures and I found a link to the trackstar motor internals. The Trackstar is actually a little more difficult to get apart. I almost need a little puller to pull the ends off, anyway here ya go. Once I get video done I will post that as well. I thought about setting up a little crawling coarse in my living room with my sons toys....;-) If I end up doing that I will post video tonight.
A front shot of both motors. ROC 412 on left, Trackstar on right.
A Side by side shot. The trackstar is a little longer due to being able to adjust timing. Which is a plus in my book.
A shot of the Rotor from the rear of it
The Front
Finally a shot of the Stator and the Hall Sensor.
Very well built motor but then again it should be for $159.99
The next set of photo's were not taken by me. That being said as soon as I make something to pull the end caps off the motor I will be taking my own pictures and will post them on here
The main differences I see currently is the trackstar has two spots to plug the sensor wire into giving you more freedom in mounting, the can is also more "open" and while that can help it run cooler it can also allow dirt and debris into it. The ROC412 has a 3mm shaft while the trackstar has a 5mm shaft I personally like the thicker shaft, haha yeah that sounds bad!:shock: Also the ROC412 front cap attaches to the can with 6 socket cap screws while the trackstar attached with three very tiny button hex screws.
Other than that the motor are very similar. Spinning the shaft even feels very simliar. Now for the road test. I will get it done in the next 7 days or so. let me know if you have any specific questions.
The Front
