OSRC
Got 2 or 3 CC01 chassis in various stages of mutilation laying around. A while ago I consolidated all of my hop ups and better ideas onto the other 5 rigs, and have a ton of leftover parts, chopped chassis, and random rickrack in a box. So one rainy day while I was looking for a project I started digging through the box ...
...and got motivated. I love working on these little trucks - no two are the same in the end. Pretty sure there's not another going to be one like this out there anywhere. But I'm getting ahead of myself. Here's what I started with. A rough chassis that was used pretty hard as an FJ in a previous life. (Actually, this was about 1/2 way through mockup. ...)
This chassis had a homebrew gear reduction that I worked up with some 5mm bore pinions and some spare parts. I've never ran it, but it tests out nice and smooth. It's about 2.5:1 as it stands, but I can change the pinions to vary the ratios. Nice little mod for about $10 in parts.
I wanted to go a different route here, so I dug through my big Tamiya suspension box and found some old Wild Dagger/TL01B arms and hubs and made everything fit. Works out to a 220mm width from hex face to hex face so it's about Axial XR mod width (ish). Rear is spaced out with some hex wideners (for now)
Dug around for some shocks in my big box of mostly old shocks, and found some Kyosho shocks from a Nitro ZR-1 Vette that have amazingly held oil for nearly 25 years, and were in very good shape. They were close enough for the rear. Some old kinda matching Kyosho nitro TR-15 shocks were the perfect size for the front. They have a built in notched adjuster for preload that is so simple and handy that every shock should come like this. In any case, I cleaned them up, dumped out the oil from both sets, drilled the pistons for crawler duty, and filled them both with 20wt oil. Started with the stock CC01 shocks out front and some Wraith purple springs out back. Total WAG on the setup...very much subject to change.
Rear shocks for mounted to some old CR01 (staying in the family this time!) chassis parts modded for shock tower duty and braced up for stiffness. Cleaned the chassis up quite a bit here too. Fuel tank here maybe?
Fronts get Hot Racing aluminum mounts up top (some upgrades I apparently forgot to rob for my other CC's) which give 3 different upper mount locations. I made a front tie bar to stiffen everything up as well. Really, it was just an excuse to drill up some speed holes.
While I was at it, I made a new radio plate just for giggles.
Have more pics, tired of typing. Here's where this is going kinda maybe sorta not sure yet but I like it:
More coming.
More coming.
