Egressor knuckles with ax10 chubs fit 300hd correct??
But it needs to be EGRESSor's AX knuckles made for XR shafts (v5xr), and not his standard AX knuckle.
Like gunnar said, if you look at the distance between the standrd AX chub & knuckle setup, therre is significantly less distance (where the cvd or universal joint it) when compared to that of XR/Wraith chub & knuckle.
Felsenfest v5xr knuckle (made for standard vertical kingpin AX chub (works with Super 300 HD's & standard AX chub
http://www.rccrawler.com/forum/axle...B4s-high-steering-knuckles-7.html#post3024421
Fenselfest standard AX knucke (works with standard Super 300 and AX chub
http://www.rccrawler.com/forum/axle...r%B4s-high-steering-knuckles.html#post1646762
Notice the difference in distance between the kingpin hole, and the two holes that secure the bearing carrier to the kingpin plates. The XR version has a greater distance between them.
If you have an AX cvd and an XR universal handy, and compare the two, you'll see why this added distance is necessary.
