I'm working on a winch setup for my TRX-4 and the most straight forward way to do it is with the wireless controllers due to the transmitter setup. I also chose an SSD OX winch which is 3s capable. The wireless controller I chose (HeyOk) is said to be 3s capable but I've read their comments about it "Yes, 3S lipo is good. Don't take the input voltage much over 12." Which makes me want to include a BEC to keep the voltage right at 12.
This setup will use a little 850mah 3s battery just for this winch.
Which leads me to my question, I plan on using a CC BEC 2.0 I have lying around to limit the voltage to 12V, but I'm a bit uncertain on how to properly hook this up when its a separate system.
I'm guessing id just used either of the red and black wires or maybe even tie them together (More amps?). This BEC has 2 leads that go to the receiver, one is power and ground and the other has power, ground and signal.
This seems safe to me but id love to get some other folks input
-Thanks
-Thanks
