New free spool Ox Power Winch from SSD! Modeled after the legendary Warn 8274 1:1 winch.
CNC machined
Aluminum case
Hardened steel gears
Scale design
Free spool using spring loaded button
Motor connector plug is compatible with RC4WD winch controllers
Mounting plate has same mounting locations as RC4WD winches
Fits SSD Hawse Fairlead (SSD00013)
Fits SSD bumpers (SSD00012, SSD00046, SSD00051)
Fits RC4WD Warn Hawse Fairlead
Specs
Height: 44.3mm
Width: 66.0mm
Depth: 24.5mm
Weight: 91g
In stock now! SSD Ox Power Winch (Free Spool)
CNC machined
Aluminum case
Scale design
Specs
Height: 44.3mm
Width: 66.0mm
Depth: 24.5mm
Weight: 91g
