Awesome write up for an awesome winch! Thanx for the great info Chris "thumbsup"
Rob
Rob
I'm the second person to ask!
"thumbsup"
Love the winch Neil!
I also would love to have the mounting boss change"thumbsup"
Sending a PM for a spool also.
I have heard of a few running 4s with a 3-way switch, no controller.well, I have been playing around with this QS winch for a couple months, and I love it "thumbsup"
I use HeyOK's standard winch controller(6V) with my QS winch now, but I would like to know what is the max. voltage that QS winch can handle with?
thanks
I use 4.7k ohm resistors to replace the pot. These ones came from Radio Shack.
1-More resistanceOK, I went to the shack and bought 2.2k-Ohm 1/4 watt 5% resistors from a thread a while ago on someones reply....what is the difference from what you used here before I go to work on my servo winch for no creep.........bob
Just a quick update. I have broke my 100lb and 130lb winch line multiple times and found some 150lb Tuf-line XP in green. We'll see how it holds up. I can still fit 30 feet on the spool.
Still running it off 12.5 volts with the TZI winch controller.
i picked up some braided stainless line from mcmaster that doesnt have the wire memory most have, rated to like 250lbs or something. it will coil up a little if you spool it all out and aint careful, but its very soft and supple compared to other steel lines ive tried.
i can look up the part number tonight if you or anyone else is interested.
