Soze's RCRun Run80 LC80 Build
soze
Orange County, CA
Another belated build recap for the RCRun Run80 that I worked on earlier this year. I had wanted to get my first hard body build done for RC4WD's Go Scale Day on May 1st. I decided to choose something uncommon and go with a very uncommon chassis. The RCRun Run80.
It's a very scale looking chassis, and the biggest worry was that I'd only be able to get parts from overseas. Decided to bite the bullet anyways, because it was a really unique platform and had all the scale looks. After building it, I've come to find that I love the way the chassis moves. It's really heavy, but it also gives it a realistic sway and bounce out on the trails.
I'm still not done with it as far as scaling it out goes, but I'll get around to it.
Follow my RCRun Run80 build on YouTube
Many of the following links are to eBay where you can find the stuff I used. As an eBay Partner, I may be compensated if you make a purchase
Kit/RTR:
RCRun Run80 - https://ebay.us/UAouhy (eBay) | https://bit.ly/3nHTTAJ (Asiatees)
Parts:
LC80 Body - https://bit.ly/3vEA9kf (Asiatees) | https://ebay.us/pQEriI (eBay)
Interior for LC80 Body - https://bit.ly/3nFuTKA (Asiatees) | https://ebay.us/Iz86VH (eBay)
Rear Ladder for LC80 Body - https://bit.ly/2RgpjCr (Asiatees) | https://ebay.us/q8vQH6 (eBay)
Spare Tire Carrier for LC80 Body - https://bit.ly/3ueE7jg (Asiatees) | https://ebay.us/8GaEvq (eBay)
Roof Rack for LC80 Body - https://bit.ly/3aWYKZU (Asiatees) | https://ebay.us/X4mBQh (eBay)
ARB Style bumper for LC80 Body - https://bit.ly/2Rj2Hkq (AliExpress) | https://ebay.us/fz5YkX (eBay)
RC4WD 9.5cti Warn Winch - https://ebay.us/YyC3pG (eBay)
SSD RC Stock Steel 1.9" Beadlocks - https://ebay.us/RxuZ5a (eBay)
Pro-Line Class 1 BFGoodrich KM3 G8 - https://ebay.us/HhUdgw (eBay)
N52 Grade Neodymium Ring Magnets 1/2",1/4",1/8" - https://ebay.us/eg14r6 (eBay)
Electronics:
FlySky GT5 Radio (eBay)
Hobbywing Quicrun 1080 ESC (eBay)
Holmes Hobbies Crawlmaster Sport 13T 540 (eBay)
KillerBody Light System Controller (eBay)
MyTrick RC 3mm LEDs Light System
Tools:
Versachem Brake Caliper Grease (available on eBay) - https://ebay.to/3p8bIZ7
Noleen SF3 Grease (available on eBay) - https://ebay.to/3jN9vB9
Permatex Anti Seize Lubricant (ebay) - https://ebay.to/3qpTbsN
Associated 1656 FT 1/4 in Driver Handle (available on eBay) - https://ebay.to/3d31t5O
Tamiya Side Cutter (available on eBay) - https://ebay.to/371SAWb
DEWALT DCF610S2R 12V MAX Cordless Lithium-Ion 1/4 in. Hex Chuck Screwdriver Kit - https://ebay.to/3tQqXcr (eBay)
MIP Metric Speed Tip Set MIP9512 - https://ebay.to/3qdBMTU (eBay)
Bob Smith Industries Blue Thread Locker - https://ebay.to/3jDR8i9 (eBay)
ProTek RC Shock Pliers (available on eBay) - https://ebay.to/372Lscs (eBay)
Duratrax Shock stand - https://ebay.to/2MOyJ6l (eBay)
Hakko FX-888D Soldering Station - https://ebay.to/3aXFmLj (eBay)
Multistar Rubber R/C Work mat - https://bit.ly/2T3F4Zo
IWISS Crimping Tool - https://ebay.to/3jGKZll (eBay)
Universal Servo Cable Wire Connector Crimp Pin Kit - https://ebay.to/3tSAAaW (eBay)
E6000 Adhesive - https://ebay.to/2MZwtZV (eBay)
Dubro Body Reamer - https://bit.ly/3sjWP8h (Amain)
Dubro Curved Lexan Scissors - https://bit.ly/3sjWP8h (Amain)
Paint:
Krylon Fusion Matte Ink Blue
<iframe width="560" height="315" src="https://www.youtube.com/embed/BQ_JX4Pw0f8" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Part 1: Axle & Transmission Grease Check
So with this kit, there isn't really much to assemble overall. The axles are mostly assembled, and the transmission is mostly assembled as well. You really need to just put together the suspension, add electronics, and mount everything up to the chassis.
I decided to take a look at the parts that had gears to make sure that they were properly greased.
These are the parts I'll be inspecting for grease
First inspection was the axles.
Axles come with CVDs
Next up for grease check is the transmission...
Yup... it's bone dry. We'll have to do something about that.
Greased it up with my trusty Versachem brake caliper grease
Now let's take a look at the tranfer case.
Yup... it's dry too.
Greased the transfer case up too.
Was originally going to put a Hobbywing Fusion in this rig
It's easy enough to mount into the transmission
Here's the problem though, this kit comes with a nice scale pulley/belt and fan system. If you plan to use it, you won't be able to fit the Hobbywing Fusion. I decided to just stick with a brushed setup and go with a Hobbywing Quicrun 1080 and a Holmes Hobbies Crawlmaster Sport 13T
<iframe width="560" height="315" src="https://www.youtube.com/embed/Ct-jLbu8HY0" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Part 2: Mounting Transmission
So... the printed instructions are terrible. Like absolutely terrible. You'll just need to feel your way through the build as well as you can with the provided printed instructions.
Supposedly there is a video that shows some stuff maybe? I didn't end up using it though.
Here is the chassis frame. It's really scale and shaped like an actual LC80 frame.
Each kit has its own serial number identification
Let's start figuring out how to mount this transmission to the frame.
First you'll need these.
And you put them on like this
Next you'll need this part. Notice how there are 2 screws already on the transmission housing. I was searching through all the bags for the correct screws for this step, only to find that they were already on the transmission housing. This will happen a few times. If you don't see the screw in the bag, it might already be installed somewhere.
Anyway that part goes here
Next you mount up the transmission to the chassis using those mounts you just installed.
<iframe width="560" height="315" src="https://www.youtube.com/embed/oK5iNV_MT64" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Part 3: Mounting Axles
I completely don't remember every step taken, but basically it was just a combination of figuring out the correct screws for the correct links to put in the correct spots.
I like that the suspension for this chassis resembles the 1:1 and that it's different from all the other linked and leafed suspension setups out there. The only other rig I know that has this kind of setup is the now discontinued RC4WD Cross Country (that rig was really short lived! Jeep issues methinks!)
First we start with putting on the spring perches and link mounts
Here are the front links
Here is the rear axle with the spring perches and link mounts on
Yes that's right, this rig has a front AND rear panhard
Links for the rear axle. What's that??!!! A missing bushing! Ugggh... I eventually got this replaced after contacting Asiatees customer service. Kudos to Asiatees for working with RCRun to get the missing parts I needed.
Front and rear axles mounted up.
<iframe width="560" height="315" src="https://www.youtube.com/embed/AnDdGVN4hws" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
So I was working on this Toyota LC80 Land Cruiser build for several weeks in order to get it done for RC4WD's Go Scale day.
I didn't get it completely done, but I still ran it anyway. Unfortunately the pin in the left front CVD axle popped out and I lost 4WD early in the day. I had to 3WD it for the rest of the day, and I was just digging ditches in the dirt due to how heavy the rig is.
Enjoy anyway though!
<iframe width="560" height="315" src="https://www.youtube.com/embed/D4D_b-M5AH4" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Wow, what a cool looking rig! Looks very scale!
I'll have to go back and watch the build vids. The running vids that I did see look really cool.:)
Absolutely incredible, love seeing this separate coil/shock setup super-scale build!
Drives really nice, too... "thumbsup"
I have been eyeing one of these chassis for a while, how has it held up? My only concern is lack of available replacement parts of things like diff gears (any drivetrain gears really) or links that look to be cast metal or CV's that type of thing.. but even with no replacement parts... it is still very tempting .. have you had to fab any replacement parts up yet?
So far the only issue I've run into is breaking the teeth off the diff gear since it's a pretty heavy rig, and I was really pushing it on a steep climb. I contacted Asiatees and they worked with RCRun to get replacement parts for the chassis up on Asiatees, so you can get replacement diff gears, shocks, bushings, and a few other things now.
The original diff gears were helical, but the replacements are straight. I'm not sure why the change unless it's for strength. So far it's been fine with the replaced diff gears though.
If there is one thing I would change on this chassis, it'd be the transmission housing. That's where all the weight of the rig comes from. It's a big cast piece of metal. Really a double-edged sword. It makes the rig move really scale like when bouncing around, but it also puts a lot of stress on the drivetrain. If you could somehow change the transmission housing to plastic, I would. Might be a good project to sort of map out the original housing and see if it can be modeled for a 3D printed version to decrease the overall weight of the rig.
I follow that chassis , and , can be mount yota or k44 rc4wd axles ??? i think yes but only see on photos and video not in real life ... y like some much that chassis
