soze
So, I bought an Axial Yeti Kit in December 2015 (sat for a year boxed in garage), and it's been exactly a year ago since I started and finished building it. Up to this point I had only built Tamiya/Kyosho Re-release kits... so it was my first modern kit and it's pretty much 100% stock. I haven't done much to it at all since last year.
It's weird.... I really like it, like the way it looks.... just haven't run it much and have gotten so distracted with scale crawlers that I haven't paid much attention to it. Well, I think I'm going to start putting some work into it.
This thread will also help me keep track of what's been done to this truck.
Follow this build on YouTube - https://www.youtube.com/playlist?list=PLnWfHyV3LtMCHfAmgg_zMErjBbIsCp9fx
Here's how it stands right now.
Most product links are to the item on eBay. As an eBay Partner, I may be compensated if you make a purchase.
Parts:
Axial 1/10 Yeti Rock Racer Kit (eBay)
Axial Racing AX30230 Spring 14x54mm 4.95lbs/in Super Firm Blue (eBay) (Front)
Axial Racing AX30217 Super Firm Spring, Blue, 14 x 90mm/3.01 lb (eBay) (Rear)
Axial Racing AX31290 AR60 OCP Full Width Axle Adapter Set (eBay) (not yet installed - will not be using AR60)
RPM Front A-Arms EXO Buggy (eBay) (installed 12/2017)
MIP X-Duty Rear C-Drive Kit for Yeti (eBay) (installed 12/2017)
CWR-3003 - Crawler Innovations Single Stage Closed Cell (eBay)
Motor:
Tenshock SC411 4-Pole 4600kv SCT Sensored Brushless (eBay)
Electronics:
Hobbywing SCT8 Pro ESC (eBay)
Savox 1268SG Servo (eBay)
Tools/Paint:
Pactra Bright Yellow (eBay)
**Upgrades added as of 3/2018**:
Xtra Speed SCX10 II HD Steel Spur Gear (56T/15T) (eBay)
Incision 00051 Incision Yeti 1/4 Stainless Steel Rear Upper Suspension Link Kit (eBay)
SSD RC HD D60 Centered Rear Axle for Wraith SMT10 Yeti (eBay)
SSD RC Wide D60 Rear Axle Conversion Kit for Yeti (eBay)
SSD RC Yeti Rear Trailing Arms (Silver) (available on eBay) (eBay)
Team KNK Axial Yeti Stainless Hardware Kit (available on eBay) (eBay)
Vanquish Yeti front Skid Plate (eBay)
M3x60mm Hex Bolt Socket Head Cap Machine Screws (to replace front arm hinge pin) (eBay)
PowerHobby Aluminum Motor Heatsink Cooling Fan For 1/10 540 / 550 Size Motor (eBay)
Boom Racing Aluminum Steering Knuckle Caster Block
Boom Racing Aluminum Rear Upper Shock Mount
Parts:
Motor:
Electronics:
Tools/Paint:
