alexchen86
Wow Hunter711 I didn't know you could cram an 1/8 motor in the Exo! How's the weight distribution when airborne since I assume your running 3s tops?
EXO is advertised "Will except 540/550 motor. I played around with different mAh batts because they are diff weights depending on size.(But you knew that). Found the one that gave me the best balance. I have many lipo's to experiment with and found what work's for me. "thumbsup" And yes, I run 3s for sure.Wow Hunter711 I didn't know you could cram an 1/8 motor in the Exo! How's the weight distribution when airborne since I assume your running 3s tops?
48/15 middle, 36/14 front & backgreat looking exo hunter, what gearing are you running?
$$$On second thought I would like one of these
Hey, I just live here. :roll:There is NO comparison or competition between the C1 and EXO....why is this even brought up still?
HPI's Coyote is a much better comparison to the EXO by far.
::HPI RACING:: - RTR Coyote DB
If you live in the lower 48, you will have it by Wed or Thursday. "thumbsup"Ordered mine today. now I'll sit in pain until it arrives. Since I ordered from RPP that probably wont be long
Fronts are fine. Put spacer on top shock mount if you have a problem. It's the rears that are a pain. You need to drill top mounting holes on chassis at a angle to get proper aligment to arm and heat gun the body where the springs hit. No problem. See post #647 of this thread.Hunter, any issues on the power stroke shocks front and rear? Read that the fronts rub the dogbones. Thanks, I have set looking to see what I'm in for.
I'm guessing you had to loose some body panel for that setup? I saw that on Amain's site when researching the shocks. Proline's no bind kit.Yes the rear Prolines are a pain. But this mod worked great for me. No drilling.
Proline Shock "No Binding" Mod - RCShortCourse.com Bulletin Board
