Nova said:
There is no meter to tell you if there is clipping...
BAN HIM...
there is most definitely a meter to tell if the signal is being clipped, its called an OSCILLOSCOPE.
and a clipped signal is FAR WORSE for the drivers than the amplifier. the amp just passes on the signal info to the driver, and if its a clipped signal that driver will try to reproduce a squared-off wave instead of a nice smooth non-clipped one. just about the only thing that a clipped signal going thru an amp will do is produce heat. and i'd much rather have a hot heatsink on a quality amp than a hot voice coil...
anyway...
bigdogrod said:
i guess i'll have to keep the power down.... it's only turned up halfway on the amp, bas boost is under half, and the sub setting on the head unit is usually 3 to 5 out of 15...
is there a meter or something i can get to tell if it's clipping?
bdr
it may just be me, but i can sure as **** hear when a sub distorts when using test tones, it may not be as easy to notice as a tweeter under a 1khz test tone but if you have a test cd with just test tones you should use that to tune pretty decently. i use bass mechanix, its a pretty good one. a sub can take alot more abuse than a smaller driver like a mid or a tweet, but they will get hot and blow if pushed to hard.
if you want my 2cents, you have everything adjusted the complete opposite way. whatever the specified pre-out voltage is on your headunit, its at that rating when your sub level is at the 'max' setting. by only having it at 3-5 you are asking your amp to produce your desired spl with a waaaaay low pre-out voltage. that in itself is a source of distortion and the reason why head units with high pre-out voltages are desired. also, with that weak signal coming from the deck and being over-amplified you are inducing an unnatural bass boost to it as well. not good.
get a test tone cd like bass mechaniks, turn the amp gain all the way down. turn the head units sub setting to 10 or so, (mine is usually at 12-13) turn bass boost and loudness off, e.q. (if you have one) flat, turn your headunits volume to about 70-75% or whatever you have established as the loudest number you can listen to it at, and then adust the gain on the amp while you play tones within your crossover range. (you didnt mention using a crossover or its settings btw)
after you get the bass mechaniks cd sounding good pop in one of your favorite cds that has alot of low end. by adjusting your amp gain with the head units sub setting at 10 you have allowed a little more voltage to be sent to the amp with cds that have less impact than one with just test tones. you should be able to just dial up the sub level on the deck, play with the e.q./bass-treble controls or enable the loudness feature and have it sound good but you can fudge a little bit and slightly crank the gain up a tad as well.
imho, i would use that bass boost only as a last resort, i would try absolutely everything, including a different amp before i resorted to using bass boost, especially in a vented enclosure.
i guess since everybody else is pimping pics heres one from my install early on. if you know enough to appreciate how damn good of a sound deadening job that is imagine the rest of it being done with the same level of craftsmanship and attention to detail. ;-)
