Small metric lathe - suggestions?
Calderwood
Fairfield ME
I'm looking at purchasing a small (bench top) lathe. It absolutely has to be a metric machine. I'm looking to use it for threading links and for boring rod in preparation for milling axle tubes on my CNC 4th axis. I would like to get something that I can convert to CNC in the future. I did all the CNC setup including wiring the "box" on my 4 axis router table so that stuff is second nature now.
What machines should I be looking at?
Ultimately whatever "machine" you buy it can do either metric or american threads depending on the gearing on the machine. Lucky for you most machines on the market are metric to start! What size is the work envelope your going to work in/materials your going to be cutting. I'd look at like the mid size benchtop Enco lathe. I believe it has a built in gearbox.
As for CNC machines... and conversion it can be done it is tricky for the mechanical side. That said if your creative its easy! :)
Exactly what has already been posted. The gear change on the lead screw is what determines the thread pitch. Any lathe is capable of cutting "metric" threads. It's actually just a number- metric or SAE. It's all about the TPI.
I've been window shopping for lathes...noticed that some of the bench top units have plastic gears...don't know if that is neccecarily a bad thing or not but seemed kinda sketchy. Anyone have that style that can testify to their longevity?
My old Micro Mark 7 x 16 had plastic gears. They worked fine because the lathe is such a light duty machine, it wouldn't take heavy cuts out of steel or brass. The best I could do was like .004-.005 per pass, anything heavier than that would cause the carriage to rock and load the motor.
I have the harbor freight 7x10 mini lathe it has th plastic gears but has been working great. So far no problems wit it at all
I would suggest, go for a used Harrison M300 lathe. These lathes were built in a time when the manufacturers were not controlled by money and sales figures like in today. They are passionately built machines that can be relied on. A machine shop close to mine has a used Harrison M300 and I have to say, I was impressed. He got it for some 2500 USD in India. The Harrison M300 has various options to thread Imperial and Metric threads. It needs a 3 phase connection, but can be run on single phase if you change its electric motor.
Harrison M300 & T300 lathes
This video explains chinese mini lathes....
<iframe width="640" height="360" src="//www.youtube.com/embed/D1eOQa1gYiU?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
One thing that no one has mentioned yet is that some of the 'el-cheapo' import lathes have axis screws that have a metric pitch, so that one revolution of the handle is more than .050, vs. a Micro Mark / old Sears-Atlas 101 or Atlas 109 lathe which has imperial threads which allows for .050 for each rotation of the handle.
This is really only an issue if you are using the scale on the handle to track travel. The imperial screw is easy to do in your head, each turn of the handle is .050, so you can count aloud .050, .100, .150, .200,.....as you crank the handle.
A simple dial indicator set up (or DRO) would make this a non-issue, but I was a cheap skate when I had my MicroMark equipment, I just used the scale on the dials. :mrgreen:
I'm sure I can do the CNC conversion. 100% confident.
I'm positive I would be disappointed with the sherline. I'm looking for something quite a bit more substantial.
Which machines are on your short list?
I'll check these out.
This is one of the reasons I mentioned it must be a metric machine. I work entirely in metric measurements and I'm sure as hell not going to spin SAE wheels and screws. That would be a nightmare.
Duuuuuuuude I have that machine. It has 1 plastic gear,no probs at all. I just want a quick change tool post. I've had the machine for 6 years.
