fyrstormer
I have a Tamiya XV-01 that I built as a FWD car. Because it has limited traction, I'm running a 30-turn crawler motor with the highest gearing that will fit in the car, plus 24 degrees of timing advance, to get the speed I want. (for the record, it still spins the front tires on takeoff.) It works fine, but I find myself wondering: What are the side-effects of running massive endbell timing *specifically* in a low-power vehicle?
As I understand it, the best power efficiency is found at near-zero timing, because each armature coil powers-up when it's in just the right position for its EM field to interact as productively as possible with the permanent magnetic field, resulting in the highest torque per watt -- but not the highest wattage, and thus not the highest top-speed. Advancing the endbell timing powers-up each armature coil before it's in ideal alignment with the permanent magnets, which causes the causes the armature's EM field to deform the permanent magnetic field, pushing it further away from the armature. This temporarily reduces the strength of the permanent magnetic field in the vicinity of the armature, making it easier for the armature to rotate through it at high speed, because a weaker permanent magnetic field can't induce as much reverse-current in the armature coils, so there is less parasitic drag. This reduced reverse-current, in turn, exerts less resistance to amperage flowing through the armature coils (similar to what happens when the motor is stalled), allowing more amperage to pass through, which increases the motor's power consumption, power output, and top speed. But higher amperage also means more heat, and running hot is the most obvious tradeoff for running massive endbell timing.
Having said all that, I'm specifically running a low-power motor in a vehicle much lighter than it was originally intended for, so overheating is not a concern in my specific circumstance. Soooo...what's to stop me from increasing the endbell timing to truly ridiculous settings? I know if I rotate the endbell more than 90 degrees, the motor will just run in reverse (a handy thing to know on the rare occasion that you buy a motor that was assembled incorrectly), but what about running 48, 60, 72, or even 84 degrees of timing? There must be some side-effect of running massive endbell timing, even if the problems of overloading and overheating are eliminated, or else it would be much more common.
Does anyone know what other disadvantages there are to running massive endbell timing, besides the risk of overheating?
