Charlie-III
OK, I didn't find a single thread but bits & pieces here & there.
For "standard sized" servos (Futaba 7955 as an example) (1.57" x 0.79" x 1.50" or for the rest of the world 40mm x 20mm x 38mm), the below is a guide on spline count.
23 splines: KO, Airtronics/Sanwa, JR, ACOMS, Solar, EXI.
24 splines: HiTec, RCD, Apollo (plus some Tower/Hobbico as HiTec makes them)
25 splines: Futaba (newer), Savox, (plus some Tower/Hobbico as Futaba makes them), traxxas 2075 digital waterproof servo, HPI, HobbyKing-BlueBird, some TowerPro [mg995], RC4WD
SOME INFO FROM SERVOCITY (11/3/2013)
Hitec Servo Splines
Futaba Servo Splines
The micro/mini servos are different, thus servos used for shafty dig units, servo digs (for MOA's) and MRC steering is a seperate issue.
If you find a correction, or want to add, feel free to do so.8)
Note: some of this came from here.... RC Groups - View Single Post - expert servo arms
"Servo Database"...... 1st page is so-so, click on the brand you're looking for at the top of the page for more info on that brand... Servo Database - RC Servo Specs and Reviews
Good clamping servo arm/horns:
Decent = GH Racing aka Golden Horizons... TowerHobbies.com | AdvancedSearch Results
Great = Robitronics.... Ultra reliable servo arms - Modellbau und Modellautos & Robitronic Machined Aluminum Single Sided Servo Horn (Short) (Grey) (24T-Hitec) [RBOR17021G] | Radios & Accessories - A Main Hobbies
Garbage = Integy (stripped 2 quickly on a HiTec 7950, they also had rubbing issues that tore up a servo.)... Billet Machined Alloy Servo Horn 24T for Hitec Servo (r=20, 24mm) for R/C or RC - Team Integy
Running 2 or more servos off a single RX channel??? May want to look at this... Boosted Servo Extensions
Hitec Servo Splines
if its not already on here, stock Losi LNC pn LOSB0812 is 23 and wraith/axial AS-2 is same as HiTec 24
