skerb
No, it does. I can't think of many guys who run a CMS in comps for that reason. "thumbsup"
I run cms in comps and it performs just as well. It's all in the setup.
Just finished doing this on mine, but ran into some issues with the vanquish stage 1 and currie links. Had to swap back to the kit aluminum steering link (currie is way too long) and also swapped the end links on the larger steering rod to the angled one to drop the lower bar to stop from hitting the servo arm. Also had to mount the serv 180 degrees,from the op.
But seems to work . Swapping the front end to 4 link tomorrow
Sitting normal
Full droop
And compressed (still slightly hits the servo horn)
The servo sits way too low with how this works. The arm should be up higher, just barely clearing the bottom of the chassis rail while steering. I tried this in the past but wasn't happy and ended up using the stock plate as a template.
using this method limits compression travel...
and as the coil spring compresses on itself...
I see this ill fitted coil spring design on more and more rigs...
why ? ...because it's easy to do ?
fact of the matter...
using this method limits compression travel... (down)
the spring's compression becomes the CO's compression limiter.
maybe only a few millimeters...
but in my book... every millimeter counts.
to each their own of course...
guess I just don't get it !?
