Sorry for the delayed response. I run 3s on everything I own. The 2200kv is in the crawler and it is fantastic. Excellent low speed control and plenty of speed with stock gearing. It actually surprised me with how quick it was at first and I ended up dropping 2 teeth on the pinion to gain even more low speed control and torque and its still plenty fast for a crawler build.
The 3500kv 540XL is in the go fast build, Qwiksilver, and it is so much more motor than I'll ever be able to use. Monster power and speed on tap. It is not the best for crawling but with a fair amount of expo and a sensitive throttle finger can be crawled without issue.
With either motor on 3S, I feel a two speed trans is completely unnecessary. I personally feel that a sensored brushless motor that is even close to the 3000kv ballpark is so versatile for this rig that adding a two speed may give you more low speed control but it will also give you a ton of wheelspeed that the chassis just cannot control. If your building a crawler, that's what it'll do well. If you build a basher or U4 racer, it will do that well too. If you build it to do both, you will have to make sacrifices to both ends of the spectrum.
