Andyjk
Made these out of some ribbon from a craft store and some wire bent into shape with some pliers. Then use glue and thread to finish it off
Also made an aerial I used the below parts
And here they are together
I then glued the ball end and joint together and began to wrap a wire around the screw
For the top, I folded the wire back over on itself
Then got some heat shrink tubing and a small ball bearing. I widened one end of the heat shrink and placed the ball bearing inside
Then place it over the top of the wire and heat and mould into the correct spot
Here's a coat hanger aerial I made out of the same wire as above.
And a sand ladder made from a strip of aluminium with holes drilled. Then brushed over with a dremel
A simple bracket made from some thin steel
Photo of the thread added to tie down straps
