Solid94
Cossie came all the way back to auburn from pollack pines to deliver some limit straps and a sleeping bag. Top quality gear!!! Installed the straps tonight in the hotel
Anyone know what's the lowest reading each cell can safely be down to on a 3s. For instance is 3.5 too low? after running the truck dead 2 of the cells read 3.8 as the other read 3.5
"Just Scale It"
I've always read that 3.2v per cell was lowest you'd want to go. So, I think you're fine. What about your 2s battery? How is that?
***** Sent from my Nokia Lumia Icon using Tapatalk *****
Ok thanks! Thats good news
Going to check the 2s shortly. I think the servo winch is draining too much power
"Just Scale It"
Do you know what voltage cutoff setting your esc is set at? You could probably set it at 3.2v and get a little more run time. Surprisingly, when I checked what my BRXL was, it was at 3v. That is why I changed it to 3.2v.
2s reads 3.7 as lowest cell
"Just Scale It"
Well. Wasn't a huge difference with winch out. Haven't charged my 2s to check duration. But I'm wondering if it's something deeper. Like bec. Or esc.
"Just Scale It"
What esc and bec are you running?
3.2v is good lipo cutoff, I've read that 3.0v is ok, but seems a little low to me, my Tekin FXR is set to auto 3s cut-off. ALWAYS balance charge your lipos! I don't like them to get more than 0.2v out of sync from lowest to highest cell voltage.
Get a room :lmao:"thumbsup"
