Jrob
Gonna do a lil evening scalin at the waterfall off sunset and 65 if anyone wants to join.
Oh and I went and found the ticket writer and explained the situation. And he says oh I'm sorry there's nothing I can do for you and tried to then give me directions on how to pay the ticket. LOL!!!!! I just turned around and got back in my truck and said have a great day. I was proud of myself cause I wanted to saybut all in all the day ended being 100$ with lunch but hey watching my lil man crawl endless lines and meeting up with some kool kats and ripping it up PRICLESS!!!!:mrgreen: thanks again for the great day guys!! My lil man just passed out and was talkin about following Martin up lines as his eyes closed, see ya on the ROCKS!!
Too cool, very nice work mike. Was martins bug glitch in out or did he put some real electronics in it?![]()
That's what the problem was first time to Folsom point an they don't have a pull out pay station like at beals. Where I'm from on the off season it's free, and when I saw the boat ramp closed and no prions anywhere, and I didn't not see the pay station there. The while time there was a 10$ bill on my center consel. Pretty funny how there's no one to take your money but they sure can sneak up and get me oh well it'was worth the day!
Shazammmm
Won't get put in before sunday I'm sureIf i can even go. Was looking good but I thought I'd run again tonight but now not until the morning so that may throw a wrench in my schedule
Shoot, I'm starting to feel bad for not pointing that out that ALL lake entry points require fee.
What turn motor are you running? I'm debating weather to upgrade to brushless or just get a new ESC for my 55T lathe. I would kind of like to have something a little faster than the 55 turn Lathe with a 12 tooth pinion. I put a 15T pinion on it but it lost a tad bit of low speed control it seems.
I have a 10.5/RS-Pro in my stadium truck and it is sooo smooth. I was thinking a 21.5 or 17.5 and a RS woiuld be good for the crawler. Or one of JRH's new stubby sensored outrunners.
If you want to go brushless to get more wheel speed but not sacrifice torque I would go with what fvrr setup. Tekin RS with 17.5t motor, do not use your Tekin RS Pro it's awesome at racing but for some odd reason it does not like the Castle Creatioin BEC, dx-dow and myself have had probably 10 BEC popped from our experimenting so it just doesn't work for crawling.
Stick with a RS and you would be good, plus they are smaller to hide. The biggest downfall to the brushless system compared to the brushed is the downhill control, brushless will tend to freewheel when going downhill on the throttle when the brushed will walk down a hill even on throttle.
If I'm reading this right it sounds like you are running a separate BEC? I thought the Tekin internal BEC was pretty robust already? The Internal BEC in my Novak was weak at 5V 1A and the steering servo would cut out all the time. But I thought the Tekin at 6V 3A would solve that. Not so? Who makes a good separate BEC? Is the smaller Castle good enough?
Sorry for the stupid questions. All my crawler knowledge is from 5 years ago. I know things have had to change a lot since then.
Workin....anybody else going out? Should be nice crawling and sunset. "thumbsup"8)
You always want to run a separate BEC when using high torque servos which majority if not all of the crawler out there do. The 3amp in the tekin still isn't enough for the high torque servos which will pull more than 3amps in a bind, I personally use 10amp small Castle Creation BEC's because they are easily programmable via castle link so you can change the voltage for 2s ready servos and cc always take care of warrenty issues easily. It also depends on your system you're running if you're running 2 winches and a high torque servo or 2 high torque servos for 4ws you might want to go with the 20amp bec which is almost the size of a sidwinder.
See65 and I had some good crawling out there last night, hit us up when you can make it. I'm only 15 min from there and deer creek so I try to get a lil crawl time in daily
Where is deer creek?
Cool - thanks for the info.
