Robotboy's X-Kill Space Invader
Robotboy
In the warmth!
I've been putting together a couple of minis. Testing out some different axles
and chassis. I will eventually take the parts I like best from each one to make
my go to mini. This one I just finished and gave a test run. It does really
well even with the small rovers.
For axles I used PatB's housings. The front has 24/8T gears, SSD C's & SSD
brass knuckles and steel universals. The rear has steel shafts and BR 27/8T
gears.
The trans has HR aluminum housing & step gear, Integy aluminum slipper,
BWD motor plate, Losi mini-s top shaft, 12T pinion & HR 61T spur, Integy
steel 50T gear and Axial 5mm output shaft.
For the chassis I picked up one of João Xkilo's Space Invader chassis. Cut from
G10 with printed skid and spacers. Very nice chassis, strong and light.
The other goodies added to complete this one; China steel driveshafts,
HH Revolver V1 280 2600kv BL motor, Castle Sidewinder Micro ESC,
spektrum RX, decased & conformalled, SPT low profile servo, direct wired,
2s 600mah lipo, Mini Pro shocks & Mini-T springs, HB 1.9 Rovers and
China 1.9 beadlocks.
Some pics....
Neat little rig bud. Nice to see all the mini builders haven't given it up.
Sent from my SM-S111DL using Tapatalk
