Robotboy
Since I put the IFS from my Trailrunner on my Gatekeeper I had a new project.
Which is a good thing, kinda, since I love to build and tinker. Not much of a
build thread as most of it was already built when I started. GK kit had an extra
hard plastic cms mount so that went in first. Built the front axle with a FT
machined diff gear and spool. Rebuilt the trans with the 11% OD option. Took
the alum. panhard mount from the GK also. I had to mess with different links
and rod ends to get the wheelbase/axle positions right for the body. WB is 12.5".
Updated Specs as of now:
MST J45C Body, elect. trays and sliders.
Element Trailrunner donor.
Element trans. w/ high OD machined gears ratio.
GPM Al. spur gear adapter & HR metal 87t spur.
HW Fusion 1800kv system. 19T pinion.
CC BEC.
Annimos 25kg servo.
TGH panhard mount.
FT machined diff gear & locker, front.
Beeftubes front axle housing.
SSD Heavy brass knuckles and rear axle weights.
SSD Aluminum C-hubs.
SSD Aluminum link mounts.
SOR rear link riser.
Club5 8mm Brass Wheel Hexes.
Club5 & FT SS high clearance links.
Incision driveshafts.
Vanquish Ripper front bumper.
China aluminum shock towers.
Chinesium 1.9 beadlocks.
Proline 1.9 Hyrax tires.
CI Lil Nova Comp cut foams, soft-front, med-rear.
3Racing winch w/ cheesy micro esc, Team3Six cable & warn hook.
CC BEC.
Annimos 25kg servo.
TGH panhard mount.
