Loving the look with the wheels...SSD?
Yep! I've got Warn lock-outs on the way for the fronts and MT alum hubs for the rears.
Redcats at 115 x 43 mm
In first post jato
:shock: I read right past that and for some reason I only saw the dimensions of the GMade tires in the first post. Sorry and thank you! "thumbsup"
4.5" is a good size. I might need to pick some up.
One thing I haven't seen mentioned is that the redcat have two different foams. The sport and pro gen7's have their own foam for each. So that could play in a part of which to choose.
White foam is pro/ grey foam is sport.
Sport foams
https://www.amainhobbies.com/redcat-everest-gen7-crawler-tire-w-sport-foam-2-rer13811/p711712
Pro foams
https://www.amainhobbies.com/redcat-everest-gen7-tires-w-pro-foam-2-rer13852/p711754
Any more reviews on these tires? work better on heavier or lighter rigs? slow or fast wheelspeed?
I'm digging the look you have for your Bronco. However, did you lose a driveshaft pin or something? You seem to be only FWD in this pic.
Sport foams
Pro foams
On my TRX4's I've so far run Flat Irons, PL Swampers ( TSL SX), and the RC4WD Boggers. Although I haven't had the chance to run on pure rock yet, on the trail the Redcat IROK's are absolutely kicking the other aforementioned tires to the curb.
I ran these new IROK's at a spot that I've run all the other tires previously, so I think the comparison is valid. The TSL's do pretty badly out here yet the Flat Irons and Boggers both do fairly well. They all have their weaknesses since there's some varying conditions between loose rock, hard-packed clay, very loose granulated dirt, and flat limestone ledges but the IROK's did much better than the others.
No idea how they'll perform rock-crawling but they just churn through loose dry loamy dirt and sand like nobody's business. You can really "feel" how deep the lugs are as they dig in. On steep hard pack [red rock] clay they also just crawl right up. I ran them for about 2.5-3 hrs and by the time they were finally coated in fine silica dust, they didn't perform as well as they did when they were clean and fresh, but they still continued to impress me. Still running with the included white foams and I think that they're actually pretty well suited for this particular tire. Decent sidewall flex but definitely not mushy unlike my buddy's PL MTR's with stock foam which are imo way too soft. Width and OD also seem to be perfect for the TRX4 Bronco... no excessive rubbing while rotating during articulation and not too thin/ not too wide. TBH ( especially for the price) I could not be happier. I think that a combination of tread pattern, soft-ish compound, and deep lugs are what make this tire such a winner. There were definitely areas where the rig struggled but that was really just the softest and/ or steepest ascents.
These are all the pics that I think best show the tires performing...
