RcBros Front Berg Tubes now In-stock and Shipping!
RcBro
RcBros Hobbies
Vendor
Oregon
When it comes to a stock berg tube you lack three things that are extremely important when competing; Weight, Diameter and Adjust ability. Our front Berg tubes have all these important attributes and all the details can be found below!
Our tubes are constructed of ultra strong and lightweight 7075 aluminum with nearly the entire diameter at .45″ giving you the ultimate in clearance!The tubes also feature an adjustable 4 link mount and splined tube ends allowing for a quick and easy splined C-Hub that will need to be installed by the customer (minor fab skills require, a drill and a tap are needed)
Each link mount features diamond etched degree marks as well as a single etched mark on the axle tube which truly allows setting the link position a snap. Align both to your desired locations, mark the hole location and drill and tap. Once the first hole is set, You follow through with a second securing the mount to the tube. Red loc-tite or Green is a must.
The outer tube is splined specifically for a Vanquish splined C-Hub. This allows adjusting caster a quick and painless process. For those running not Splined C's, we do offer a machining service. Or some dremel work and they will slide right on!
Our tubes come pre-notched and a provided servo mount included allowing the customer to quickly add a servo of there choice. Please note the buyer will need to create there own servo shims to shim the servo to there desired height.
All these combined the entire kit comes in at 43 grams keeping the weight low! Lightweight, adjustable and small in size, this is the ultimate combination!
Complete Front set is $85.00!!
AVAILABLE HERE
Customer Rides:
