Honeyman108
BUZZZZZZ.... RCBee Here and her is my intro into the 1.9 scale rigs with my Gspeed V3 Honey Dipper Comp Rig and was able to add great parts from a purchase and spare parts from my current Gspeed build. The rig runs great will post video soon! Definitely want to put a forward motor mount and swap the servo down to the axle With the Vanquish Currie F9 Kit and add the Kimbrough Spur and TGH Spur locker and some shock adjustments should make this thing worthy of being a Gspeed rig!!! BUZZZZZ........
Parts list:
Gspeed V3 Carbon Fiber Chassis
Gspeed DSM servo mount
Gspeed pan hard mount
Tgh 2 low transmission with overdrive
Traxxas big bore shocks 90mm w/ dravtech caps,mounts,lower spring retainers, mini T springs.
12.3 wheel base with custom bent links alluminum upper and delrin lower links all high clearanced and SSD Steering links Titanium and Hardcore RC Bent Panhard Bar
Custom cage powder coated black. Cage unbolts from chassis pretty easy...
Vanquish black f9 axle housings with 6bolt gears and lockers 30/8 is gearing in diffs.
Vanquish steering knuckles-red
Vanquish servo horn
Vanquish OG 2.2 OMF wheels
Vanquish wheel weights-front.
Proline super swampers 5.4 inch tires smaller of the 2.2’s.
Crawler innovation dual stage foam only in rear tires. Stock foams front.
Boom racing drive shafts
Holmes Hobbies Puller Pro Stubby 540 3300kv
Castle Mamba x ESC
Reefs 777 Servo
DSM Off Road Recovery Bungee cords
BUZZZZZZ......
Parts list:
Vanquish servo horn
Castle Mamba x ESC
Reefs 777 Servo
BUZZZZZZ......
