RC4WD MT 2.2 Stamped Steel Wheels
pvo_srt4
Toronto
Guys need some help...I have these wheels but the hub is incorrect.
anyone know what hubs i will need to make these work on my Yeti? The vanquish ones do not work
here are the wheels
I use those same hubs on my VP SLW wheels so I know a VP hub will work. You just need to file or sand off the center of the hub. The hole centers are just slightly but work fine.
i ordered a set of VP SLW hubs and they should be here shortly but i couldnt wait so i took the stock plastic hubs and shaved them down to fit on the MT wheels "thumbsup" :mrgreen:
front
rear
finished product :mrgreen: finally i can run this thing without worrying the tires are going to fall off :flipoff:
the rim hub has to sit correctly on the pin that's the only reason everyone is having so many issues with stripped hubs. Also tighten down the wheels nuts and use serated nuts helps.
This is also a temporary fix :)
