You missed my point. To get most kids into this part of the hobby their parents will need to purchase...
-Battery charger(good quality)
A peak charger is good enough to get started, not everyone stays in it for the long haul.
-Batteries, at least 3-4 packs(~$40-50 each)
Only need two packs for a crawler.... And even a custom built pack from CBP is cheaper then you qoute.
-Soldering iron/gun
$15 gets you a weller.
-Solder station
Most people do not even have a station that have been in the hobby for years. Think basics, not what you run....
-Battery connectors(Deans)
Bender still runs tamiya plugs, and wins.
-Radio(Spektrum so no frustration with crystals)
AM or FM is just fine....
-Servo(s)
in 2.2 a 645 or 5645 is all they need, but yes that is needed.
-Tools(most kids just entering this hobby will have nothing)
a set of hex drivers, #1 and #2 phillips driver, some flatblades, pliers and needle nose to get started, and a tamiya wrench.
-Truck kit, TLT, WK or Axial... what about $150-220?
-ESC(brushless capable?)
-Motor(s)(brushless?)
-Chassis, ~$60-120
-Bearings
Bushings work fine... I ran bushings for a entire season, won plenty of comps with them.
-Gears, pinion/spur
-Upgraded parts(axle-c's, CVD's, servo mounts, etc..)
Don't need any of that to get started.... Other then servo mounts.
-Spare parts
Until you know what will break, not needed.
-Tires
-Wheels
-Tackle box to hold supplies
Most people have something they can use to get started.
-Dremel w/bits
I never use my dremel, I find a hacksaw and file are faster and cleaner most of the time.
-plus more...
There is a lot more than just a kit to get into this hobby. Most people tend to forget about all the small things that get used for this hobby. If a kid has nothing, which means nothing....someone will have to buy the stuff. So some will say make it yourself... who will drive the kid to the hardware store to BUY the items needed.
In the end, after buying the tools, kits and needed supplies..... Anyone will be right up too $1000. Common sense would tell you that.
I too can say that I have only $300 into my 2.2 rig.... But it's what was used to make that 2.2 is what counts. If you had to use tools, did those have to be purchased or
